I have removed the steering wheel and noticed that this connector is not connected to anything...
Does anyone know where this should be connected?
Steering Wheel removal
Re: Steering Wheel removal
Stuffed if I know
However
Not all plugs have anything to plug into in the first place as they are for different options or models or test points
However
bumblebee wrote:Stuffed if I know
However
Because i have already tried it without plugging the connector and it didn't work, I'm certainly sure that this has to be plugged otherwise how could it work without getting any power from the connector if it wasn't plugged?
I have heard that some Lancers doesn't have the harness for the paddle shifters and some do. I'm not sure now if I have the wiring harness to make them work..
I just made them work by plugging a cable into the 3 pin connector and they work like a charm!!! right now I just need to fix the alignment .....
Yay!!
