Ralliart hood
Dr No0b
Ralliart hood
Postby Dr No0b » Tue Jan 07, 2020 10:11 pm
Will a Ralliart hood fit and fenders fit my 09 Lancer es
Re: Ralliart hood
Postby bumblebee » Wed Jan 08, 2020 5:40 am
The bonnet does , I have one on mine
Never tried the fender , I wouldn't be surprised if it does fit
Dr No0b
Re: Ralliart hood
Postby Dr No0b » Thu Jan 09, 2020 11:06 pm
If it get a hood do I need anything else to put it on or does it go straight on
Re: Ralliart hood
Postby lancerdarryl » Fri Jan 10, 2020 5:40 am
They're a straight swap so you shouldn't need anything else.
Re: Ralliart hood
Postby bumblebee » Fri Jan 10, 2020 5:59 am
You will need an extra person to help you remove it and that's it
One the bonnet it dup follow the water line on the left, the black Bose to the windscreen washers
Follow that hose
It goes to a 90 degree plastic elbow
The hose will disconnect there pretty easy
It just pulls a part
Lift the bonnet up
Shove some rubber under the rear corners of the bonnet between the bonnet and windscreen incase you drop it when undoing bolts
Goes someone to hold the font while loosen of bolts on one side
Do not remove bolts all the way
Loosen of bolts on the other side
Do not remove all the way
Once all bolts are backed off and someone holding it
Then you can remove all bolts
Do 2 on one side
Goto other side and help hold bonnet and do other side
So both of.you should be holding bonnet and llift it away
When bring new bonnet back
You can lower it on to the rubber you laid on windscreen before to get yourself into position
A pair of things works best for rubber
One person on each side of bonnet
Lift it and put bolt in most of the way on all four
Do then up snug but not firm
Need to check alignment
Align the bonnet with back bolt off a touch and wiggle bonnet
Or gentle tape with rubber mallet on edges
Check the latch at front
Is it lined up?
If all lined.up tighten up 4 X bolts under bonnet on hinges
Plug in black hose to the windscreen washers
Close bonnet
Test windscreen washers
Done
Enjoy
Users browsing this forum: No registered users and 39 guests
