Page 2 of 3
Posted: Sun Jul 08, 2012 11:46 pm
by RMN116
Syke wrote:do you notice a big difference between the factory and aftermarket strut brace?
The stock strut bar is usually hollow where as the Ultra Racing strut bar is solid. Depending on how fast you take corners yes they make a difference.
Posted: Mon Jul 09, 2012 8:28 am
by LZY_EYE
The UR is hollow as well.
I helped scraverx install a whiteline to his RX, and the quality was top notch. The UR does the job, I can't see the OEM being any different, only I have seen a couple of OEM ones on evo and RA develop some small cracks.
Posted: Mon Jul 09, 2012 11:59 am
by debonaire
milobob wrote:I added a VRX strut bar to my now ex-VR - it did make a bit of a difference to turn-ins. Funny though - not all sporty or good drivers cars come with strut bars? I assume its because the chasis is so stiff anyway you dont need one.
Mmm, I put a front strut bar on my old Skyline just because I found one for cheap in a clearance pile.... it did made absolutely big fat
zero difference. But seems like people here have had positive experiences with the Lancer.
Posted: Wed Jul 11, 2012 4:03 pm
by RennieJames
Posted: Wed Jul 11, 2012 8:30 pm
by Dire
If I get a strut bar will it make my steering lighter? With coilovers my car is already trying to shoot off the road over average bumps and I don't want to make it worse
Also I found this yesterday:
http://www.onautos.com.au/p-3399-mitsubishi-lancer-ralliart-cj-08-on-brace-strut-towr-f.aspx
Posted: Wed Jul 11, 2012 8:41 pm
by RennieJames
@Dire
Sorry man i have know clue
I only recently started looking at strut bars and everyone here said it makes a difference so i got one
Posted: Wed Jul 11, 2012 8:45 pm
by Neo
I have had my strut bar for 2 weeks now, i took it off yesterday to see if i could notice a difference. You really notice a difference in cornering but if you drive like a granny then you wont notice much difference
(i have a ultra racing front strut $177inc delivery)
Posted: Wed Jul 11, 2012 8:52 pm
by LZY_EYE
If your car is trying to shoot off the road, there is something wrong with the setup. Could be poorly setup coilovers, or alignment.
Posted: Thu Jul 12, 2012 1:20 am
by Dire
It travels straight, the steering is just very light and it follows bumps or dips unless I hold onto it (which isn't hard thanks to the lightness).
Posted: Thu Jul 12, 2012 2:55 am
by LZY_EYE
How much pressure are you running in the tyres? Still sounds like something is not right. It should track the same as it did with stock suspension. Either way, a strut brace won't affect that behaviour.
Posted: Thu Jul 12, 2012 12:10 pm
by empror
I have a similar problem, I get massive amounts of road steer, but that could be because I have low profile tyres because of my 18's, or at least that's what a lot of people tell me.
Posted: Thu Jul 12, 2012 12:13 pm
by LZY_EYE
I had 17s on mine with coilovers, and unless there were some bad ruts in the road, or the tyre pressure was not right it was fine.
How hard go you have the coilovers set?
Posted: Thu Jul 12, 2012 12:17 pm
by empror
I'm still on stock suspension unfortunately
And yeah I've tested different tyre pressures, and they make slight differences, but not enough. I actually have a feeling my steering wheel has somehow become misaligned, because i have to almost permanently hold the wheel down to the right slightly
Posted: Thu Jul 12, 2012 12:20 pm
by LZY_EYE
There is a reason for that, when they do the wheel alignment, they are lazy and don't line up the wheel dead straight when they lock it in place.
Take it for a wheel alignment, and stress the importance of getting the wheel dead straight. Always check it when they have done the alignment too...
Posted: Thu Jul 12, 2012 12:22 pm
by empror
I'm glad that's an easily fixed error then! I'll get another alignment next week then I guess. I have pretty average eyesight though, so checking the alignment myself might be a bit interesting hahaha
