I have a 2010 Lancer Ralliart and have noticed that if the Iphone is within 20cm of the key, the car has problems starting.
My brother has a blackberry and he has something similar happen also with his ralliart.
Spoke to Mitsubishi and they haven't heard about this happening.
Has anyone come across this before?
Ignition Problems with my Ralliart
Re: Ignition Problems with my Ralliart
Maybe mitsubishi can recode the keys to a different frequency
ii dunno, i think the frequency is determined by there wireless sender in the key, that transmits a code to tell the cars key ECU to unlock, allowstart, ect. i would presume the sender is the same in all cars.
the main problem with, that tho is the overlapping of signal. so the stronger/closer signal will take preferance over the other, at the same signal.
so i think the main thing you can do is either have your phone away from your key, or have the key closer then the phone to the keys ECU.
Thanks for that mate, i'll give it a try to see it helps
- shamrockshirts
- Lancer Ralliart
