Brakes, brakes, running out of brakes.
All Brake Modifications.
Mitsiman
Postby Mitsiman » Mon Jun 15, 2009 11:18 am
The problem with squeaking etc is not so much the pads, bt the rotors. Factory Mitsubishi rotors have always been bad, and when you put good ceramic pads on them, they just become horrible sometimes. I highly recomend that if you do a RDA rotor / EBC Pad combination you won't go backwards
For urgent replies to PM's contact via phone
aussiera
Postby aussiera » Mon Sep 13, 2010 1:36 pm
I am in Bundaberg in qld and am struggling to find a supplier of greenstuff pads for my Ralliart lancer, any suggestions.
Car came with aftermarket pads on it (No marking so not sure what they are) Braking is great but has chewed a set of front disks in 25k.
Thanks
McCoy
Postby McCoy » Thu Oct 14, 2010 11:36 am
Hawk Performance Ceramic. Fronts are $166, low noise, low dust and work well with higher temps.
Dyno's
An invaluable tuning tool when used correctly
An invaluable sales tool when used incorrectly
smithsy
Postby smithsy » Thu Oct 14, 2010 11:45 am
Dont get greens for an RA, get the Reds. Reds still perform perfectly fine on the lancer from cold. Get a stop or two into them though and they will ave alot more bite.
I have had no wears issues after doing around 30,000km+ on my RDA Slotted and Dimpled rotors with the EBC Red Stuff pads. They would have also had quite a few heavy heat cycles over the last 12+ months aswell...
kinesis
Project Team Member
Postby kinesis » Wed Oct 20, 2010 8:13 pm
Check out our latest sponsor GSL RallySport. They stock a whole set of different types of brakes.
GSL RallySport Brakes
GSL RallySport thread
Blitz Air Filter | RPW Stage 1 ECU Flash Tune | UR Front Tower Strut Bar | UR Rear Lower Bar
Alpine iDA-X305 headunit | LED Taillights | VG Sharkfin Antenna
Return to “Brakes”
