Off
On 100% power
Headlight's on DRL's 50% power
I used a 5 pin relay, which has one Normally Open and one Normally Closed circuit with a switching signal to switch between the two:
There are two types of 5 pin, one that activates two pins when the circuit is thrown, and one that switche between two pins. The differencve is that th first kind will have two 87 pins, the second will have an 87 and an 87A. You want the second type, I got it from supercheap. The way I have it wired up is this:
(30) 12v main: Accessory wire (spliced into cigarette lighter)
(85) Earth: Car Chassis
(87A) Load on NC circuit: Wired down to DRLs positive
(87) Load on NO Circuit: Not used
(86) Switch Wire: For this I spliced into the blue wire leading to the driver side park lamp.
With this setup, whenever the ACC power is on, the DRLs operate. When the headlights/parkers come on, the circuit gets broken, so the DRLs turn off.
I actually also incorporated my foglights by slicing the DRL positive wire into the positive wire on the Driver side fog light. This means that my DRLS + Fogs run whenever ACC is turned on, they both turn off when the headlights come on, but if I hit the foglight switch, the fogs and DRLs come on and headlights remain on. If you're not incorporating your fogs though, just do the relay part and the fogs will just function independently.
If this still doesn't make sense, let me know and I'll find time to draw up a full wiring diagram.
