After a fun filled day of installing a sound system in the es, we sat down with a beer and plugged in the battery...
that's when the fun began... after i plugged it in within seconds smoke arose from under the drivers seat. and also a loud noise
turns out dad had got two yellow wires mixed up for the rear divers side speakers. so that yellow line is fried.....
ill get a picture up soon.
any suggestions?
SMOKIN
Speaker lines around the wrong way won't cause smoke. All that will do is put that speaker out of phase.
What amp, what gauge wiring, what fuse size under the bonnet?
If there was a short on the power cable then fuse would blow.
My guess us power supply in amp but really need to know what gear and what else was amp running.
Amateur hour much, I always ALWAYS triple check every single connection and cut I make before I go any where near the battery. Your not glueing on cheap ebay parts here it is a very real possibility that you could have set your car on fire or even bricked the entire electronics system if you shorted the car that well.
I see it all the time here people try things themselves and F#@% it up or do a S#$% poor job of it. Take your time, think about what you are doing and pay close attention to detail. Makes me scared about even considering buying a second hand car.
n_aghdassi
gotta say i have done a few installs now and never heard of any frying/smoke... but i guess if u destroyed the cable then its more than possible...
but for future reference you should never wire something up to an unknown cable, use something like a 9v battery or a test pen to see what speaker is which and to see the correct powers...
there should be some wiring diagrams out there as well mate, i wish i had the link but there is actually a site that will tell you every wire in any car and were it goes etc for all stereo items in your car.... but i lost it a year or two back, but simply check at each end of it, you should run new cable but sometimes its not always nessasary or easy to do... can be quiet fiddly in car door boots if you havent done it before....
either way it sounds like it could be your amp fuse, generally if you put power into the amp speaker lines the fuse will blow and melt.... thus giving u a plastic smell and can some times smoke... check the fuse on the amp, find out what the cable does and replace it.... check all your lines are correct and fix it up mate....
without seeing it i dont think anyone can really help as to yet.
Thats a bummer man! 1st time installs can be a bit nerve wracking.
im sure someone will come up with a wiring diagram for you. i found this, from mr charisma:
My aftermarket harness has:
Yellow - Constant 12V
Red - Acc 12V
Black - Ground
Orange - Illumination
Blue - Aerial
Blue / White - Remote Turn On
Green - Handbrake
Speaker wires ( white, grey, green, purple )
from this thread, might be helpful.
http://clubcj.net/viewtopic.php?t=7841& ... ker+wiring
So long as the car starts, and runs, with no warnings, i'd say no terminal damage... I would recommend pulling all fuses related to the headunit/amps etc. you've installed, till the wiring is checked out with a multimeter though mate.
Good luck with it! and don't give up, home installs are extremely satisfying, i've done all my cars myself, and the music sounds sweeter when its your own work!
Red - Acc 12V
Black - Ground
Blue - Aerial
Green - Handbrake
n_aghdassi
