OUTLANDER CLUSTER
- ofey
- Alumni
Well if you really can't see it, you can't.
To answer your question, No it won't it.
The whole cluster is single part i.e. The speedometer, info display & Rev meter with the dual hump top.
You cannot just swap over the central bit with the information display.
If you cannot see the middle bit, you can also get the colour display out of a MY12 VRX cluster.
The part is around A$800+ through your local dealer.
I'm not sure if there is an install fee as you will need to re-program the mileage onto the new display.
