Hi Guys,
i have installed the new LED tail lights
i have fitted them with the resistor as well but i have some intermittent problems with them
The right side parker lights dont always turn on.
for example if i unlock the car the first time, the right side wont turn on. i have to lock it and unlock it twice and then it turns on and the same happens when i am driving around. i have to turn off/on lights for the parker lights to turn on.
this used to never happen with my original lights.
also the front parkers seem to be linked with the taillights somehow.
Anyone else have the same problem ?
Problems with LED Tail lights
ive double checked all connections
OEM lights work fine. when i put the LED lights they work intermittently.
it doesnt work the first 2 times and then works fine until the car is switched off and let alone for a while and the same problem starts for the first 2 times and then again goes back to normal behaviour
My problem was that if the drivers side parker was not on, the right tail lights would not work. It took a few unlocks before it turned on.
If you do an isolation test, you'll find that if you use higher power bulbs (I tested with stock and another set of LED's from a friend) the problem is resolved.
Anyway, I bought these http://www.ebay.com.au/itm/T10-car-Whit ... 46004867f8
As far as why the passenger side parkers aren't affected, it's probably due to the circuitry of the car. I didn't have a multimeter available at the time, so I didn't bother measuring the voltage and current.
My theory would be that since the car is designed for LHD (park brake on LHS...) the circuitry would be done so in the same manner. The drivers side is probably connected in parallel with the passenger side, splitting the current and not allowing the ECU to detect it properly (controls power flow to lighting), since it draws very low amounts [of current] it caused hyperflash because the ECU thinks the bulb is blown.
Then again, that's all pure speculation, and I'm sure its much more complicated. Maybe an EE like Ofey could explain... I'm just a ME with basic circuitry knowledge haha.
TL;DR - Buy those bulbs from the link and you'll be fine.
