Now that I've upgraded to wider rims and tyres I want a set of mud guards (not mud flaps).
I rang Mitsubishi and they don't make any.
Can anyone reccomend any or has anyone fitted or used these?
http://www.ebay.com.au/itm/MUD-FLAPS-SP ... 43aa6460c7
Mud guards for Ralliart
Hi turbogirl.
I heard these rallyarmor mud flaps are great.
http://www.rallyarmor.com/store/0713-mi ... 16c0b99ba4
Love That Car.
mitsu make them for the front only tg, unless theyve dropped them.
i have them on mine
http://clubcj.net/garage.php?mode=view_ ... ge_id=5285
i have them on mine
Cammo00 wrote:Hi turbogirl. I heard these rallyarmor mud flaps are great. http://www.rallyarmor.com/store/0713-mi ... 16c0b99ba4
Chris these look great, I love them but not sure it's the look I'm after, hmmm decisions........
sleeper wrote:mitsu make them for the front only tg, unless theyve dropped them. i have them on mine http://clubcj.net/garage.php?mode=view_ ... ge_id=5285
When I rang Mitsubishi today they said they didn't make any in this style to fit over the side skirts so I assume Steve they don't make them anymore
Hoges wrote:I have the RallyArmour mud flaps. They look great
These look fantastic Ryan!
Well I'm not in a huge rush I might sit on it and check out what people have at the meet on Sunday. I don't want anything that sticks out the side too much and takes away from the wheels which now nicely fill the guards or how fat the tyre look from behind the car
- ofey
- Alumni
turbogirl wrote:sleeper wrote:mitsu make them for the front only tg, unless theyve dropped them. i have them on mine http://clubcj.net/garage.php?mode=view_ ... ge_id=5285
When I rang Mitsubishi today they said they didnt make any in this style to fit over the side skirts so I assume Steve they dont make them anymore
Mitsubishi are idiots.
Here's the part number you need for the same part as Steve:
Mud Flaps Front (with OEM Sideskirts)
MZ314116 Mud Flaps Front
RRP=A$31.1+
CCJ=A$31
Before ordering: Read this
Jade I fitted a set of VRX rear mudguards/flaps to my Ralliart.All that is required is drill an 8mm hole in the bottom of the side skirt when you fit them.Having said that I didn't leave them on for long as they are of little use I put a set of Rallyarmor urethane mudflaps on the car.......much more gooder
Plus they have a range of different colours for the logo
VRX rears fitted to the Ralliart
did you buy them off ebay?
i can only find ones to suit an Evo on ebay. I fairly sure they wont fit
Syke
Check Out My Garage
Check Out My Garage
lancerdarryl wrote:Jade I fitted a set of VRX rear mudguards/flaps to my Ralliart.All that is required is drill an 8mm hole in the bottom of the side skirt when you fit them.Having said that I didnt leave them on for long as they are of little use I put a set of Rallyarmor urethane mudflaps on the car.......much more gooder [img:feabab13d7]http://www.clubcj.net/img/images/20130115023943_RALLYARMORMUDFLAPS002.JPG[/img:feabab13d7] Plus they have a range of different colours for the logo[img:feabab13d7]http://www.clubcj.net/img/images/1358178512_RALLYARMORMUDFLAPS008.JPG[/img:feabab13d7]VRX rears fitted to the Ralliart
Thanks Darryl, the VRX ones you mentioned are the ones I'm after it's good to know though they are of little use. Where did you buy yours from?
Hey, would anyone know if EX lancer mudspats will fit the rallart?
even if it's just the back ones ,it will do. thanks
http://rover.ebay.com/rover/0/e11401.m1 ... AAU%3A3160
bongo wrote:Hey, would anyone know if EX lancer mudspats will fit the rallart? even if its just the back ones ,it will do. thanks http://rover.ebay.com/rover/0/e11401.m1 ... AAU%3A3160
Unfortunatly I don't think they would fit it says for models without side skirts and body kits, this would rule out the RA
