hey guys,
i recently went on ebay to buy some LED DRL strips and a controller to automatically switch them on when the car turns on and switch off when the head lights turn on, however what i am stuck with is why the DRL controller doesnt turn off the DRL's when the car is turned off.
http://www.ebay.com.au/itm/350645212717 ... 1497.l2649
E.g. to turn off the DRL's i would need to turn off my car and turn on the head lights to effectively turn them off...
Do you guys know any other way of getting the DRL's to turn off when the car turns off?
the Controller is hooked to the Battery and the tripping wire is linked to the headlight fuse.
Any suggestions would be highly regarded!
DRL help!
You have + and - and i believe the other wire has to be hooked up to the light switch... hmm so the white wire is also a positive (+) i belive it can be hooked up to accessories or positive, in that way when you turn your car off the DRL's will go off as well,
What i would do if i was you, i was gonna hook up the positive and negative straight to the parkers, but that's just an idea!
