Brakes, brakes, running out of brakes.
dumb&
I might just buy some neons instead!!!!
Only kidding.
Red stuff take about 2000km to bed in apparently..only thing putting me off them at the moment. Slotted rotors just wear down the brake pads quicker and are only needed if you're tracking your car for extended periods of time really...though if they were cheap enough it might be worth looking into.
Only kidding.
Dummer
$290 there abouts for a set of RDA slotted rotors or $550 for grooved and dimpled RDA rotors.
Yeah thats the point, they wear the pad quicker, but more braking force, not to mention it lets the gases escape and provides added cooling. Oh and yeah redstuff has a long bedin time (upto 2500km) but I think the outcome should be worth it. Our cars are quite heavy to pull up and even 15-20mins on Wakefield park will put some decent heat into your brakes and I dont know that green stuffs would handle that given my OEM pads cooked up nicely??
Dummer
You would of got them a bit too hot on the pass, but you didn't cook them... Mine were leaving black scorch marks on the rotor as they had got that hot they melted the bonding agent and it had seeped through the pad and was burning onto the rotor
$175 for front red stuff and rears aren't in the country, they need to be specially ordered and will take months!
But with our strong dollar I am looking at sourcing from the US. However I am in two minds, as I have a set of Bendix HDs on atm, so considering waiting until later in the year and then buy new rotors and pads once I've worn the Bendix's out a bit more
- ZERO COOL
Ryan_C wrote:When I can get together some dosh later this year I plan on getting EBC redstuff and some slotted rotors for the front I think, my experience has been that the rears are adequate and it's only the fronts that are lacking.
EBC's are good. When I do my new brake setup thats what im going with.
- Mitsiman
- Lancer Ralliart
We market, use and recomend the green stuff pads. THey are fantastic and most of the track cars we work on, use the reds or yellows for the serious cars.
For you guy's on stock cars on the street, I recomend the greens which are perfect. I use greens on my magna for street driving.
If your in perth, we do stock the EBC range as well.
For urgent replies to PM's contact via phone
- spareparts
- Lancer Ralliart
i used ebc green stuff on my statesman and didnt like it, i would put bendix ultimate's or ferodo formula's, i now the seven hills cops got a ralliart and the got ultimate's in the front and bendix 4wd in the rear from a pajero. the rear calapers are differnt from the ralliart to the vrx but fronts are the same, even consider a set of bda slotteds. i will not put drilled on a street car i have seen them crack
the voices may not be real, but they have some pretty good ideas
:D
Dummer
Mitsiman wrote:We market, use and recomend the green stuff pads. THey are fantastic and most of the track cars we work on, use the reds or yellows for the serious cars.
I'm told Greens won't withstand the temperature the pads can get to on a track day??
Spareparts when I checked earlier this year Bendix don't do ultimates for our car.
- Mr Charisma
Use some Ferodo pads and they where horrible.
Bendix pads worked ok but they don't make the ones I got.
Last set where EBC green, took a solid 1000km to bed in properly and for the squeeks to go away but after that they where very good.
Hawk make some really good pads ( and would be m choice ) not sure if they make them for the Lancer though.
Love that car!
- spareparts
- Lancer Ralliart
Dummer
spareparts wrote:well thats what i was told landers put on the cop ralliart from the work shop control which i work along side for 12 months
I talked to people from both Ferodo and Bendix in early march and they had nothing for the VRX (which supposedly has the same front pads as the RA) and nothing planned in the near future. A brake workshop down here said that they could get Ferodo performance pads custom made but it'd be like $400-500 a set. Maybe they sourced a custom set of pads for the front...
