Quick Sale! Evo X Brembos w/ discs and pads
Any info on where you got these from? and also what needs to be done to fit them to the RA as I'd like to upgrade my brakes soon, but unsure whether to go this route or go with the bolt on kit from MRT.
2012 Ralliart Lancer
- UR Catback
- Relocated Battery
- Gruppe M Carbon Intake
- Grimmspeed 3port
- Beebletooned
- BC BR Coilovers
- Whiteline Swaybars
- TE37SL
- UR Catback
- Relocated Battery
- Grimmspeed 3port
- Beebletooned
- BC BR Coilovers
- TE37SL
here's a link to some photos and talk about installing evo x brembos on an RA
http://forums.evolutionm.net/09-ralliar ... art-8.html
as u can see in the photo there is a a huge gap between where the brembo bolts on and the RA's Hub
- poe_sniper
- Lancer VR/GT
I've fitted Evo X Brembos on the rear (requires about 2.5mm of milling) and I've fitted Evo 6,7,8,9 Brembos to the front coupled with an Evo X Rotor. I did this with a 'dogbone bracket'. I didn't get the Evo X ones as the 'arms' are much longer than the previous evo brembos and would come into contact with the hub.
