Quick question guys, a mate got some LED globes for his Subie the other day for $40, anyone know if the LED's are compatible in the '09 lancers?
If so you guys got any idea what ones to go for?
***Edit***
i'm not entirely sure if finding some of the headlight spec. led bulb would be a match, thought i would ask first
Lancer Bulb List!
- Ronan.Butler11
Re: Lancer Bulb List!
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
'09 Lancer VRX
Modifications:
18" King Rims
Ralliart Snorkel
Re:
Lancer1993 wrote:
Anyone tried fitting a 4x4 style light bar to their CJ?
I have one of these. 15inch about 240 watt mounted to a licence plate bracket and works a treat
BCF currently is doing amazing run out deals on LED bars
Their 20 inch bar is down from about $300 to just $110 and is Amazingly bright. They have two styles.there is a spot light bar and there is a combo bar that has both spot and flood in the same bar. They also come with a 3 yr warranty. Attached to the front with a bracket that bolts to the back of the licence plate.works a treat
The 20 inch bar looks great on the front of the lancer
The 30 inch is a bit big they are $158 at BCF
Slightly overkill on the lancer but if that's all the shop has then grab it you wont be disappointed
For a plug n play wiring kit get one from "Stedi" in Melbourne. Keep your eyes on them in ebay.you can get them on special delivered for about $40 or less
ZERO COOL wrote:Front of car:
Front turn signal light: 21watts bulb: WY21W
Head light, high beam: 60watts bulb: 9005 HB3
Head light, low beam: (halogen bulb) 51watts bulb: 9006 HB4
front foglight: 55watts bulb: H11
Front side marker and parking light: 5watts bulb: WY5W 194
Side turn signal light: 5watts bulb: W5W 195
REAR of car:
High mounted stop light: ---watts bulb: -----
License plate: 5watts bulb: W5W 194
back up light: 21watts bulb: 7440
tail light: 5watts bulb: W5W 194
tail and stop light: 21/5watts bulb 7443
rear turn signal: 21watts bulb: 7440
rear sidemarker: 5watts bulb: W5W 194
Are these the same for the CF models?
- Quismiff
Apart from the 5w park light they should be, as the DRLs in the bumper serve as the parkers to satisfy ADR rules, you'll notice they dim when the headlights come on.
2007 MY08 VR-X
Quismiff wrote:Apart from the 5w park light they should be, as the DRLs in the bumper serve as the parkers to satisfy ADR rules, you'll notice they dim when the headlights come on.
cool thanks, thats what i thought, thinking of buying some new 4k+globes high and low.
My LED parker (or position) lights are flickering, they are LEDs bought about 4-5 years ago on eBay. I think they are only doing it at idle but will be checking later this morning. I think they have been doing it for some time.
SCA has some for about $15 depending on the brightness.
BTW this was also noted at the service Friday.
Should they be replaced?
I know they are a bugger to get to and with my left hand out of action I don't want to do one and not the other.
Spend $30 at autobarn get the 100 lumens aerpro units
Worth every penny
Worth every penny
Found a spare (must have been a 3 pack) anyway replaced the flickering on.
Should do for now, got the stock bulbs in glove box if needed on the trip.
Couldn't find them on the AutoBarn website, will keep them in mind next time I go past, will need to restrict my driving this week, between the leak on the water pump and my finger driving my CJ right now is not fun
Re: Re:
First I need to ask what is the type of bulb used in the reversing lights? Looking at getting something brighter on eBay.
Also and I should have asked this sooner but relaxing on Boxing day watching some TV and online...
But how secure is the licence plate bracket? Doesn't seem to have much behind it.
Anyway before any other trips I might get something like and light bar sorted even if I leave it off the car most of the time and is just a cheap eBay one.
Cree seems to be a popular brand for around $50, some including the licence plate bracket but no wiring. But with time I can get the bits and not be in a rush to fit them.
bumblebee wrote: I have one of these. 15inch about 240 watt mounted to a licence plate bracket and works a treat
Don't bother with the eBay led bars
Been there
Done that
Don't waste your money
Today is the day to get decent led bars on special from autobarn or Supercheap
The bracket behind the licence plate is quite sturdy.
At idle there is a very slight vibration on the led bar and you can see the light shake
Get it above 1000 rpm and vibration goes all together
Been there
Done that
