Lancer1993 wrote:Dumb question but is there any easy way to test the spot lights I have?
Not used them in years and right now I've got nothing wired up but I might have enough bits to rig up something over the weekend.
They are GE sealed beams about 110mm across. (I'll post a photo later today)
EDITED... I checked this on last week, just to get an idea how it looks, last time I used it was with the coupe about 4 years ago!
If you just to check if they work just touch the ends on a car battery terminal, if you've got 3 wires (a positive, a high beam ine (the one the switch is on) and an earth, just touch the earth on negative and the other two on positive). If you have a jump starter you can use that too.
