deano1964 wrote:Also, Fog lights are another thing that get me peeved off. I have only used mine 3 or 4 times, in foggy conditions like they are meant to be used. ANDROS, the newer cars are not actually "driving lights" as 'driving lights" must only come on with the high beams, as per the ADR. So they are fog lights. Whether or not the optics in the fog lights are designed for this purpose is another matter. Compare the output and beam pattern of a European or Japanese car's fog light to that of a Commodore/Falcon and you'll soon see which ones were designed for vanity over function.
Well actually.....What makes a fog light is the fog pattern. Inside a fog light is a small light diffuser that spreads the light out sideways and reduces the distance. Many cars have lights that shoot straight forward and are basically another set of lights (just like headlights) on the car but at a lower level.
I know what makes a fog light a fog light. BUT what I was saying is the manufacturers wire them up as and call them fog lights, regardless of the type of lens etc. Hence my comment comparing European lights and Commdores.
Back on topic. Note I was not the one who sent this thread off topic to start with...
HID's Installed
drake89 wrote:from 12 October 2009 its illegal to use fog lights in clear weather. If you drive with fog lights on in clear weather you risk being fined A$40.
It's been law for years. Just never policed.
Australian Road Rules wrote:The driver of a vehicle fitted with front fog lights or rear fog
lights must not operate the fog light unless the driver is driving in fog or other hazardous weather conditions causing reduced visibility.
Offence provision.
- drake89
negitive... it was only ever illegal for REAR fog lights and never policed. it was never illeagal for front to be used up until the 12 of oct 2009.
its an amendment in queensland transport legislation starting 12/08/09
http://www.transport.qld.gov.au/resources/file/eb74670b62f0269/Pdf_qld_road_rules_11_sept_09.pdf
Page 2
Page 2
drake89 wrote:negitive... it was only ever illegal for REAR fog lights and never policed. it was never illeagal for front to be used up until the 12 of oct 2009
It has been for front and rears. For years. Believe me lol
Read for yourself:
Link to PDF
as per ADR all HID's are illegal Unless... see below
i got this from the Department of Transport and Main Roads.in an email
Major components required for ADR-77 are; As you would be aware, vehicle manufacturers are now fitting High Intensity Discharge (HID) bulbs to vehicles from factory. It is also possible to fit these assemblies to vehicles aftermarket, as long as the Australian Design Rule (ADR) requirements for HID lights are met. These requirements are:installation of headlight leveling deviceinstallation of a headlight washer systemstandard requirements for the performance of headlights are still met (distance of illumination, dip to the left, project a white light etc) There is no modification approval needed to perform this replacement, however compliance to the full requirements of headlights (as mentioned above) must be met.
- ANDROS
obviously since we have installed them we are aware of the legal implications.... and guess what... WE DONT CARE!
Stop complaining, you have said it enough times! this is a thread showing the final product.. if you want to complain about HID's make your own thread!
___________________________________________________
