Tryg!
Can you do tadzy a favor?
Could you possibly measure the exhaust outlet dimension on the talon body kit? Just need the diameter of the outlet to get an idea on what size tip i could get in there...
Thanks budz!!
Rear Diffuser - just ordered....
To be honest, I didn't keep them.. they were both given away in boxes, but a cursory look told me they are the same size as the ones shown below (but not as neatly finished as the double-skinned ones from Supercheap shown).. let me show you the ones I have used with dimensions...
These are from Supercheap, are 304 Stainless at $50 each.... They are double-skinned and are straight cut. You could get any with the same external diameter of 75mm, or slightly more, remember that your exhaust does move (bounce) on the hangers, so making it tight would also probably result in them touching the bar... Leaving them smaller (around the size of the above) makes any movement very controllable... if that makes sense.
Good luck with your project Tadz !
Yeah, they are a bit small when you see a GReddy up close and see how utterly sex they are on the car (saw Draevon's up close today).. much bigger diameter and quite in-your-face, which is good...
But, I think the small diameter may be a good thing, as I would not want the exhaust too free-flowing, noting the concerns by many regarding backpressure requirements etc.. Two will look good, even if only 75mm...
There were some 89mm ones at Supercheap, they would look good too!
Honestly, you will need some form of hole there to allow the caught air to escape.. it acts like a bit of a parachute otherwise.. if you could mount it up in the centre and leave the surrounds as mesh, that would look utterly sick!
I believe you actually lose some economy from adding this type of mod...
Just food for thought Krz, but your car is one of my favs on here, the addition of a Talon on yours would just make it pop even more..
If you can leave the mesh surrounding a taillight (make it like a rear fog) it would be so very unique!
Good luck!
Good luck!
