options on sst oil change???
R4LLI4RT
Postby R4LLI4RT » Thu Feb 06, 2014 10:01 am
seriously this is exciting man. cant wait to see how this 'super battle' wages out. who will have the closest results to oem.
3Inch Custom Cat Back Exhaust
Home Brand Alloy UICP
K&N Panel Filter Replacement
DBA Extreme Pads
Turbosmart Dual Port BOV
Tein S Tech Springs
Beeble
Postby Beeble » Thu Feb 06, 2014 10:38 am
My sample pots should get there Friday or Monday i'm guessing. posted Wed morning from VIC. but mine has the control fluid in it so I guess you are kinda waiting on that one!
http://BeebleTune.com
BST50N
Postby BST50N » Thu Feb 06, 2014 11:42 am
Beeble wrote:My sample pots should get there Friday or Monday im guessing. posted Wed morning from VIC. but mine has the control fluid in it so I guess you are kinda waiting on that one!
Yeah control fluid will really bring it all together.
So far: Motul = golden yellow, LiquiMoly= brownish, HKS= green
All very different in colour! Will share results as I get them.
Beeble
Postby Beeble » Thu Feb 06, 2014 11:47 am
yeah I think motul and martini might look veeeeeeeeery similar heheh
liquimoly looks like ravenol
megatron
Postby megatron » Thu Feb 06, 2014 1:00 pm
Beeble wrote:yeah I think motul and martini might look veeeeeeeeery similar heheh liquimoly looks like ravenol
liquimoly is ravenol, liquioly sales rep has confirmed that for me in the past
Beeble
Postby Beeble » Thu Feb 06, 2014 1:05 pm
^^ I had heard that too - good to see and hear it from another source.
BST50N
Postby BST50N » Thu Feb 06, 2014 1:17 pm
Ok so first initial results with LiquiMoly, Motul and HKS from FTIR spectroscopy.
VERY SIMILAR! FTIR tells you what fucntional groups are present, ie gives you an idea of chemical make up. These three are very similar, so obviously the same sort of chemistry. FTIR isn't good at detecting very small trace amounts, so anything in there at low % won't likely show up. LiqiMoly and Motul look almost identical, and the HKS is veeeeery close, but I'm seeing a small additional peak in the HKS fluid - could be why its green.
poe_sniper
Postby poe_sniper » Thu Feb 06, 2014 2:41 pm
Cool :-). Just looked up what an FTIR is and was looking at the diagram and it looks very similar to a Michelson and Morley Interferometer.
R4LLI4RT
Postby R4LLI4RT » Thu Feb 06, 2014 2:42 pm
so what exactly are the properties you are comparing? will you be making some kind of diagram?
DBA Extreme Pads
Tein S Tech Springs
BST50N
Postby BST50N » Thu Feb 06, 2014 4:21 pm
Yeah the actual physics of how an FTIR works makes my head hurt. I learnt about it in uni, but cant remember now.
R4LLI4RT wrote:so what exactly are the properties you are comparing? will you be making some kind of diagram?
Chris check my previous posts about what properties I'll compare. I'll probably post up a diagram of the FTIR spectra so people can see the differences themselves. I can also do this for the thermal analysis.
MORE RESULTS:
So as I said before from the FTIR, the LiquiMoly, Motul and HKS are very similar. The small peak difference i mentioned before was probably just noise.
I just got the sample of the Ford fluid this arvo and compared - Interesting finding = the Ford stuff has some noticeable differences. There are two significant peak shifts in the ester groups, and one peak that the other three have is not there. Its still very similar, but slightly different, if you get my drift. Its obviously very similar chemistry, but i suspect there is some differences in the molecular arrangements of the esters.
Thermal analysis of LiquiMoly, Motul and HKS shows they are similar. All start to break down at about 300 deg C, and decompose at about 345-350. Haven't done the Ford yet.
Troupy
Postby Troupy » Thu Feb 06, 2014 7:23 pm
Great work Nicholas, thank you!
Chris, Motul is approx. $30/L retail available in litre bottles from autobarn etc. Took a couple of days for it to be ordered in at the local Newy outlet.
El-Diablo
Postby El-Diablo » Thu Feb 06, 2014 8:06 pm
Any chance you can get hold of the Fuchs oil for a comparo
Beeble
Postby Beeble » Thu Feb 06, 2014 8:16 pm
^ buy some :)
BST50N
Postby BST50N » Thu Feb 06, 2014 10:05 pm
If anyone buys some I'll test it:)
El-Diablo
Postby El-Diablo » Thu Feb 06, 2014 10:09 pm
I will see if i can get hold of some where do i need to sende it my understanding is its not expensive
