2009 Lancer Auto Tramsmission Fluid Change
Gleno
Re: 2009 Lancer Auto Tramsmission Fluid Change
Postby Gleno » Sat Jan 30, 2021 7:41 am
mototo wrote:i used CVTz50 to reset my deterioration values.
i used 8l. bought a 20l drum of j1.
first drain 4 plus litres
second drain 3 plus litres.
this was at 70000kms. 7 years in. i am the 3rd owner of the car.
drives much better.
fluid out was not pitch black, quite dark but definitely not the nice green it was in. i did not change the filters either.
Its now done almost 80000kms and the fluid is still a nice green tinge. maybe its just me but it seems to hold the torque better whilst consistently accelerating and keeping the revs past 4k.
there is a guide here in the DIY on how to do it.
http://clubcj.net/viewtopic.php?f=21&t=13416
You stated Green ? My CVT fluid has always been red when brand new :shock:
Postby bumblebee » Sat Jan 30, 2021 8:00 am
Different manufacturers use different colours for their fluids
Rillanon
Postby Rillanon » Sat Jan 30, 2021 11:59 am
I actually found a guide in the how-to section
https://www.repco.com.au/en/parts-servi ... sion%20kit
comes with pan filter and cooler filter, no O ring tho
Postby bumblebee » Sat Jan 30, 2021 6:42 pm
Nice searching skills, well done
If anyone interested here is some extra goodies
https://support.google.com/websearch/an ... 6433?hl=en
https://ahrefs.com/blog/google-advanced ... operators/
Once you master Google, searching the viewable web is much easier
Chisvrx
Postby Chisvrx » Sun Jan 31, 2021 6:47 pm
Thanks Adam, I think the 2.4 CVT has 4 cooling lines instead of 2, think I read this a while ago. I will call a few Mitsi dealers and independent mechanics too see what is their view in the cooler filter/pan strainer filter.
PS4 tires
AK Racing air filter/RA snorkel
iDrive TC
Rear sway bar 22mm
Sony head unit
Stage 1 sound deadening
Plasti dip front/rear/mirrors
Red brake calipers
Door scuff plates
Aero wipers
Black/alloy wheel centre caps
Aluminum shift knob/hand brake
Leather steering wheel cover
Amplified Shark antenna
Chisvrx
Postby Chisvrx » Wed Feb 03, 2021 12:20 pm
bumblebee wrote:To the best of my knowledge the CVT on the 4b12 and 4b11 is identical
Having said that I'm sure I stumbled across a reset of some kind the other day for CVT fluid in something's
I have a feeling it may have been mmcoding writing software where I saw it , but don't quote me on that
I think the CVT cooler of the 2.0 has 2 ports and the 2.4 has 4 but I could be wrong.
PS4 tires
iDrive TC
Rear sway bar 22mm
Sony head unit
Red brake calipers
Door scuff plates
Aero wipers
Postby lancerdarryl » Wed Feb 03, 2021 12:22 pm
The cooler has two coolant ports and two oil ports on either transmission— they are the same.
Postby bumblebee » Wed Feb 03, 2021 3:14 pm
lancerdarryl wrote:The cooler has two coolant ports and two oil ports on either transmission— they are the same.
Legend
Cheers for that
