Lancer Throttle Controller
chump
Re: Lancer Throttle Controller
Postby chump » Tue Jul 06, 2021 9:49 pm
bumblebee wrote:i suggest you grab a mobile phone, set it to video mode, get it recording, with the light on so you can see the rear of the plug while it is still mounted and watch the video you make.
you can also remove the 2 x bolts holding the throttle to the firewall to make it easier to see the plug
Ok good idea. Thanks again for your help.
awood
Postby awood » Wed Jul 07, 2021 10:03 am
It's very simple , there is a clip to pry out of the way at the same time lifting up on the plug with minimal pressure to pop it off.
Shine a bright torch up in there and it will become clear.
Hardest part is contorting yourself in under the dash to get access.
Postby bumblebee » Wed Jul 07, 2021 4:42 pm
slide the seat all the way back, and lay in the floor on your back with feet either outside or up on the seat
also to make life easier, there is a small cover you can remove just above the pedals, held in with 3 plastic clips , that will let you in and see easier
also, grab a service manual , check the forum
Return to “Interior”
