You will be fine with what your trying to power. Even if you get one of those ciggarette lighter adapter things which takes the one plug and makes it 3 or 4, that should give you a quick idea if it works or not. But you should be fine with that stuff
12v Cig Lighter socket- how much can it handle and best way?
- tadz0rz
Have you checked under your cupholder? There should be a harness under there which has a 12v signal...Not 100% sure if it applies to evos though.
Tried searching 'fuse box' and 'electrical circuit diagram' but can't find anything which shows how we can tap into the 12v power supply from the box. My installer has asked me to try and find this so we don't need to rip out the cig lighter/interior trim to find it. If anyone has it, can they please make a new sticky thread for it?
look in your car book(Manuel) that you should have in your car., it has where and what fuses does what.
there should be a 10A fuse for your cig lighter may be called accessories, that's why it says max 120W. it will most likely be in the inside fuse box id presume.
billyboy wrote:There's the fusebox behind the glovebox, is that where you want to tap into?
There is a diagram of all the circuits behind your glovebox, will see ciggy the symbol & find the corresponding fuse on the panel. Might be a bit fiddly getting behind there.
its not really take the glovebox out, and its pretty spacious. getting to the wire, may be a bit harder, but just unmount the fusebox and should be good.
