SST Fluid comparison - Results
- zedd82
Jacks Transmissions in the US say that they have tried several different fluids in the SST and always go back to Diaqueen because they have issues with the other fluids.
At the bottom of the product description half way down the page http://www.jackstransmissions.com/collections/tc-sst-evo-mr-6-speed/products/mitsubishi-sst-trans-fluid
it also depends on their driving conditions.
are looking to thrash it on tracks or just use it for street.
3Inch Custom Cat Back Exhaust
Home Brand Alloy UICP
K&N Panel Filter Replacement
DBA Extreme Pads
Turbosmart Dual Port BOV
Tein S Tech Springs
DBA Extreme Pads
Tein S Tech Springs
Hi Nic, Sorry have not sent you more ford fluid will send some early next week
Gary
I'm waiting on a couple of samples. Things like viscosity and density need to be tested on the same day, to minimize variation in room temperature and humidity (even though the lab is supposed to be controlled I'm sure it varies by a couple of deg).
I'm going to try one more time with the thermal analysis using a hermetically sealed sample container. If I cant get repeatable results with that I'm giving up on that one
All good it is on its way now just posted now gary
I sent about as much as last time hope that is enough Gary
