Ralliart brake pads
All Brake Modifications.
Postby sleeper » Mon Aug 10, 2015 9:21 am
DBA 4000 t3 seems to be the preffered option
i coulped those with REMSA pads and dot4 600 fluid, works well :)
check out GSLrallysport, they`ll know which part number you`ll need.
squala
Postby squala » Mon Aug 10, 2015 10:07 am
Bigger rotors for the Ralliart are quite tricky. Firstly, the stock rims are not gonna clear. You can get Evo X wheels, but need to roll the rear guards because they're wider.
Poe_sniper has done a backdoor conversion to Brembo rotors, a costly, complex but effective setup that's almost as good as the X itself. Perhaps shoot him a PM; he's a very helpful guy.
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
Postby sleeper » Mon Aug 10, 2015 10:09 am
Speedie has too :)
DJV133
Postby DJV133 » Mon Aug 10, 2015 11:03 am
Ok guys. Thanks. I am
Running the stock 18" Ralliart rims plasti dipped. I want to keep those rims. Does anyone know if I can do a straight rotor upgrade?
DJV133
Postby DJV133 » Mon Aug 10, 2015 12:52 pm
Awesome feedback. Thanks. I might just upgrade to the standard rda rotors then. Sounds like a much better option for me and will fit with the stock rims. I think I will just paint the callipers to give it a more unique look.
squala
Postby squala » Mon Aug 10, 2015 1:06 pm
With slotted rotors, I'd go for DBA. They're T3 front and T2 rear, with QFM HPX pads on all four sides.
I can try grabbing the part numbers for you when I find the boxes.
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
DJV133
Postby DJV133 » Mon Aug 10, 2015 1:44 pm
Ok squala. Sure. If you're confident and certain they will fit on stock ralliart 18" rims. Otherwise I'll just go with the standard dab upgraded rotors.
squala
Postby squala » Mon Aug 10, 2015 2:03 pm
I'll look for them when I get home.
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
squala
Postby squala » Tue Aug 11, 2015 8:39 am
DBA4417S front (T3)
DBA2213S rear (T2)
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
DJV133
Postby DJV133 » Tue Aug 11, 2015 11:53 am
Thanks Squala. So will these parts you specified for on stock ralliart rims?
DJV133
Postby DJV133 » Wed Aug 12, 2015 10:08 pm
Bump. Bump
Jason-VR
Postby Jason-VR » Wed Aug 12, 2015 10:14 pm
They are the same size as standard so of course they will fit your rims. The only time you need to worry about it is when you change to a completely different brake set-up like brembo.
trevordd
Re: Ralliart brake pads
Postby trevordd » Fri Sep 30, 2016 12:07 am
I am going to get some ceramic pads from http://www.crossdrilledrotors.ca/econo- ... -kits.html website of me. I have heard a lot of positive reviews on them, so I guess it will be a great upgrade for my ride.
Return to “Brakes”
