Blue LED Dash Lights
- JazzyB
How's the wiring work oz? like, if u've got a few lighting things (ie door-neons, these lights ^, other tings) do u have a hub or just a heap of wires twisted together at a certain point in the dash?
I wanna do stuff like this but i'd wanna plan it all and do it in 1 hit if possible, minimise taking the dash apart - but what's the protocol when installing multiple stuffs?
wiring led are pretty easy if its a premade thing it would be just straight power and negative to another one.
if its custom made you would need a resister to make sure you have the right voltage across all the led's if you want multiple led runs you put them in parallel so the voltage stays the same across all the runs.
i could draw a picture but if you search google for it they have automated thing for correct voltage for bulb colour and tells you how many you can put in a run and what resister to use.
