3M Di-Noc Carbon Roof + Parts (More Photos)
JaCe
Postby JaCe » Sun Jun 05, 2011 1:35 am
bernardo wrote:Nice, I wonder how much professional labour costs ...
Well I've been quoted from a few places circa $350-$600 for the roof including parts and labour in Sydney... but in this space, price varies considerably with experience and reputation.
JaCe
Postby JaCe » Mon Jun 06, 2011 8:20 pm
draevon wrote:I took the aerial off, laid the vinyl, then refitted the aerial :)
Are you able to shed some light on removing the aerial? Did you have to undo the interior trim to remove it?
draevon
Postby draevon » Mon Jun 06, 2011 9:40 pm
Yep you have to take the headlining off, then there's something on the inside of the roof that holds it in. I can't remember exactly sorry, it's been a while, but it's pretty obvious once you're in there.
JaCe
Postby JaCe » Mon Jun 06, 2011 11:05 pm
Thanks for the tip. Would you recommend that approach of taking the lining out or precutting the vinyl around it?
draevon
Postby draevon » Tue Jun 07, 2011 8:50 am
Definately take the time to pull your aerial off. From memory it only took me a couple of minutes to figure it out, and it's going to look a lot better then cutting around the base of the aerial I think. Also if you got the cutting wrong in any way, you're going to have a little pice of white roof showing through. I don't know about you, but that'd make me want to pull it all off and start again :)
Defs worth a few minutes to remove the aerial.
JaCe
Postby JaCe » Tue Jun 07, 2011 8:12 pm
When you say it only takes a few minutes, is that including the time taken to figure out how to remove the headlining?
Thanks!
draevon
Postby draevon » Tue Jun 07, 2011 8:35 pm
Aha :) Yep ... I think you just remove the C-pillar covers, pull back some of the rubber edging around the doors, then there's two Christmas tree like clips holding it up there. Pull those out, and you're in.
Postby LZY_EYE » Tue Jun 07, 2011 9:07 pm
I have had my roof lining out in the CJ Jeff. Let me know if I can be of any assistance :)
JaCe
Postby JaCe » Tue Jun 07, 2011 9:10 pm
Thanks guys. Just trying to help the guy out who will do the vinyl wrap- he's a friend of a friend. Any other tips/tricks you have for getting the roof lining out would be greatly appreciated as this is for someone who has never worked on the car, and also for me who isn't very good at all.
Postby LZY_EYE » Tue Jun 07, 2011 9:17 pm
From memory there are 10mm bolts holding the C pillars in. There are xmas tree clips at the rear like Tim suggested.
I don't think it would need to pull it out all the way
JaCe
Postby JaCe » Sat Jun 11, 2011 7:26 pm
Thanks again for the advice guys. Ended up getting it done today by Carbon Demon and Mike + Wendy did a fantastic job (and they removed the antenna for a clean install).
Here are the photos-
Image Image Image Image Image
draevon
Postby draevon » Mon Jun 13, 2011 12:53 pm
Sick
n_aghdassi
Postby n_aghdassi » Fri Jun 17, 2011 12:20 pm
that is a really good job. it inspired me actually!
did you use the same glue from the interior to do the roof aswell?
Concord Customs
Club Sponsor
Club Sponsor
Postby Concord Customs » Mon Aug 22, 2011 10:28 am
hey everyone,
just so you know, 3M have released a new carbon wrap product in black, white and grey and the film is actually thinner and allows more flex. it is also cheaper and has a 10year guarantee against affect by the sun. more importantly, it is also wider on the roll which means it will be easier to use on your roof and bonnet
....Custom Car Builders....
CLICK HERE FOR OUR WEBSITE
draevon
Postby draevon » Mon Aug 22, 2011 10:39 am
What's it called?
Return to “ClubCJ Talk”
Users browsing this forum: No registered users and 85 guests
