Okay so im breathing life into an old thread but ive just had the warning come up...
I would like to avoid the 2k in costs to get this replaced. I spoke to mitsu and they said that they actually increase the percentages values for stretch and that the chain should only be replaced if the engine is noisey... wtf.
If I send my car to mitsu they are going to destroy my engine. It was parramatta btw.
Fitting the New Timing Chain
Hi so is 2000 what mitsu had qouted you ???????? I am getting mitsu to do visual check on my timing chain at my next service ????? ? Gary
Hi my car has not thrown the code yet !!!! but want to get it checked out anyway I kicked up a bit of a stink on my my last service as it was the last one in warranty time . dealer offered to visually check it out on my next service so I am keen to see what they say????
I hope it will not cost $2000 to replace it if it is close to it's limit s gary
Ok i had my chain replaced under warranty after it broke. Here is what you need to do.
What year is your car? Ask the dealer to check what chain you have. Tell them you know it is a known warranty issue and you want it replaced before it breaks, the old chain tensioner and oiler are no longer available as they have been withdrawn.
This is what is called a notification undewr a dealer notice which means it isn't a recall but when vehicles come in for service they are meant to check if its still ok.
Tell them you know a design change happened in MY2011/2012 i'm not sure which/there is clearly a design fault and you want it rectified.
If they persist write and say you will be making a claim under consumer protection laws as the part was clearly not fit for purpose and the failure is not considered normal wear and tear.
As for any other members standard 4B11 turbos fail in both the evo and ralliart due to this issue. Any one considering a turbo upgrade should check the level of chain they have and change to the latest version it will save you a lot of money down the track.
- belle_tb_ES
- Post Monster
If worst comes to worst....and it needs to be replaced try and save to get other things eg water pump and thermostat?? Not sure if they come out too
Hi yes I did tell my dealer I new of the chain issue, as I said I jump and down a bit that is when they offered to look at next service i took heaps info about the chtain problem but they judt offered to check it next time gary
So wait Adam, they are saying that the chain streching isnt a warranty issue?
how many kms have you got?? If they say its not call up mitsu austrlia and question it.
my cars chain streched, and in their wisdom they said 'oh we will just clear the code and see what happens' 2 weeks later it came back and i had 2 wait 2 weeks before they could change it, 14000kms later my cams have now gone stupid, beeble had a look and told me what the code was displaying.
dont let them push you back saying its not warranty, push them until they are pissed off at you, remember your paying for that car not them
3Inch Custom Cat Back Exhaust
Home Brand Alloy UICP
K&N Panel Filter Replacement
DBA Extreme Pads
Turbosmart Dual Port BOV
Tein S Tech Springs
DBA Extreme Pads
Tein S Tech Springs
