SST Fluid comparison - Results
yeah ofcourse, everything we do is at our own risk.
i ve spoken with some others who have used the ford stuff and say that everything is running well and its been a few months now.
3Inch Custom Cat Back Exhaust
Home Brand Alloy UICP
K&N Panel Filter Replacement
DBA Extreme Pads
Turbosmart Dual Port BOV
Tein S Tech Springs
DBA Extreme Pads
Tein S Tech Springs
chris wrote:How do the Phosphorus levels of Transmax Dual , Ford and Diaqueen compare I see in the us tests Diaqueen had a higher level than the others tested.
No idea - though this would be interesting to know. I can't test for levels of phosphorus unfortunately.
I did price the transmax at repco it is around $600 for 20 litre drum on speacil order . They had to ring castrol to get item number . Gazza
I went into the Virginia repco I was quoted around the $490 mark at first but i went back to double ckeck the price they told me it was closer to the $600 mark they quoted thr wrong price Gazza
Ok. I might pop in on the weekend to my local one see if there is a difference since you are in another state
DBA Extreme Pads
Tein S Tech Springs
DBA Extreme Pads
Tein S Tech Springs
even if the castrol transmax dual is $600 for 20 l its still cheaper then the ford stuff its only $1.45 cheaper a ltr.
but the advantage to the ford stuff is you can buy it in 1l bottles
DBA Extreme Pads
Tein S Tech Springs
DBA Extreme Pads
Tein S Tech Springs
