LED reverse lights for... sportsbacks
craigeth
Postby craigeth » Wed Jan 11, 2012 6:43 pm
I know that you can't get full LED taillights for sportsback, but is it possible to swap out the reverse bulb for an LED one?
Cheers
www.twentythreeframes.com
Gleno
Postby Gleno » Wed Jan 11, 2012 6:45 pm
If its the same type of socket as the sedan,it shouldnt be a problem ??
craigeth
Postby craigeth » Wed Jan 11, 2012 6:50 pm
I'll have to check out my mates sedan now...
Dire
Postby Dire » Wed Jan 11, 2012 8:58 pm
Read the manual?...
tadz0rz
Postby tadz0rz » Wed Jan 11, 2012 9:00 pm
Apparently from what I remember, the reverse light bulbs are the same type of bulb that are in the sedan however there is less room in there. I remeber a while back we did a group buy on reverse lights and im pretty sure one of the buyers was a sportback and due to the size of the LED bulb it wouldnt fit in the tail light itself.
Something to consider...
Postby LZY_EYE » Wed Jan 11, 2012 9:00 pm
From memory the reverse globes between the sedan and sportback are different. You should still be able to get globes for them though.
The Sedan is a T20 wedge, I think the Sportback is a T15 but don't quote me....
craigeth
Postby craigeth » Wed Jan 11, 2012 9:15 pm
Thanks guys.
MRWOLF
Postby MRWOLF » Wed Jan 11, 2012 10:17 pm
I've got Article Blue Parker lights in there
It's a pain to get your hands in there it's a tight fit but you should be fine
Don't ask what T type they are but they are Parker's
Mine's quicker then yours!!!
Range Rover Sport 2014-
2013 WRX: 2013-
2009 Lancer: 2010-2013
2003 Astra: 2008-2010
craigeth
Postby craigeth » Wed Jan 11, 2012 10:48 pm
Ive got T10 parkers in the front, I think I've stills got the blue ones I had to take out a while ago.. Might try them tomorrow.
MRWOLF
Postby MRWOLF » Wed Jan 11, 2012 11:09 pm
Take your time as there isn't much room between the lights and the boot and it should be anti-clockwise turn and pull
2013 WRX: 2013-
Tin_Pusher
Postby Tin_Pusher » Thu Jan 12, 2012 8:42 am
Correct, that was me. No way would the lamps fit, so I moved them onto someone who had a sedan.
Here's a pix of the difference:
Reverse lamp on steroids .....
squala
Postby squala » Wed Mar 28, 2012 9:08 am
I fitted LEDs for my reverse lights, but the problem is, when I back up, the lights only go on for about 3 seconds then turn off completely. Anyone know the reason behind this?
Thanks
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
Postby LZY_EYE » Wed Mar 28, 2012 9:18 am
I have heard some LED globes doing this. Might need to try another set...
squala
Postby squala » Wed Mar 28, 2012 9:21 am
Yeah, I tried two different sets already, same result. :evil:
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
