Aftermarket headlights questions...
joey0828
Postby joey0828 » Sun Aug 26, 2012 11:10 pm
Is 2008 Lancer VR headlights same as 2010-2012 Lancer?
ijustatecurry
Postby ijustatecurry » Sun Aug 26, 2012 11:15 pm
51W HB4 globe will do the trick for all of them (standard low beam headlight) - Narva and Philips pretty popular options
joey0828
Postby joey0828 » Sun Aug 26, 2012 11:21 pm
I want to buy this ( http://www.ebay.com.au/itm/120938858887 ... 4845wt_908) but the ad said 2010-on, so not sure if it will fit 08 Lancer.
mwang1990
Postby mwang1990 » Mon Aug 27, 2012 1:02 am
joey0828 wrote:I want to buy this ( http://www.ebay.com.au/itm/120938858887 ... 4845wt_908) but the ad said 2010-on, so not sure if it will fit 08 Lancer.
I have these on my '10 lancer and they are a direct replacement. Perfect fitment. You will need different globes though from the stock HB4 to H7 for low beams. High beams are included and parkers are the led strips and halos
mwang1990
Postby mwang1990 » Mon Aug 27, 2012 1:03 am
Im pretty sure 08 to the current model uses the same lights.
joey0828
Postby joey0828 » Mon Aug 27, 2012 1:19 am
That's what I thought. Just want to make sure before I buy it, so it dosen't come with low beams lights?
mwang1990
Postby mwang1990 » Mon Aug 27, 2012 2:57 am
It does not come with low beam bulbs. Just buy some H7 bulbs are your good to go. I installed HIDs into mine. Decent H7 halogen bulbs could cost around $50 im guessing. I paid $99 from Autoplatomium and got a complete HID kit shipped to my house
joey0828
Postby joey0828 » Mon Aug 27, 2012 11:22 am
Thanks... Michael.
I asked the seller from eBay twice about the fitment . They still say No. It won't fit my car... That holding me back.....
squala
Postby squala » Mon Aug 27, 2012 11:51 am
I took out the aftermarket bulbs off my 2009 Platinum and putting them on my current car without issues. And AFAIK, Mitsu has not designed different shape headlights for newer Lancers.
Ask the seller to explain why it would only fit 2010+ models and not older ones.
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
big_d
Postby big_d » Mon Aug 27, 2012 12:50 pm
Sorry to hijack your thread, but I have a question about headlights also that may help answer why different headlight options exist.
My VRX has HID headlights as standard (NZ spec), as a factory feature these headlights have Adaptive Front Lighting or AFS (lights that come on when you turn a corner - see YouTube videos for reference) – so the inside lights are angled towards the outside of the car to make this work.
My question is, are there any aftermarket headlights that fit (and work with) the factory HID and AFS set-up?
[youtube]http://www.youtube.com/watch?v=7GMYt79xYbw[/youtube]
[youtube]http://www.youtube.com/watch?v=OnYyW2LHFXI[/youtube]
joey0828
Postby joey0828 » Mon Aug 27, 2012 2:11 pm
squala wrote:I took out the aftermarket bulbs off my 2009 Platinum and putting them on my current car without issues. And AFAIK, Mitsu has not designed different shape headlights for newer Lancers. Ask the seller to explain why it would only fit 2010+ models and not older ones.
I think the the factory who make this headlights mention it 2010-ON, so the seller have no idea what's different between 2007-2012 Lancer. They just follow what factory said.
mwang1990
Postby mwang1990 » Mon Aug 27, 2012 3:44 pm
big_d wrote:My question is, are there any aftermarket headlights that fit (and work with) the factory HID and AFS set-up?
Depending on what type bulb is in the factory HID cause it only fits H7 and I highly doubt it comes with the AFS set up as well.
