I have fitted both and it is a lot easier to fit a plain piece and then cut and it looks better too.
If you really want precut then carefully peel the old one off and take it to a sign writer and they will be able to cut you a fresh piece the same shape.
NEEDED: Another pre-cut matt blackout vinyl
yup I agree with Troy, unless you get the alignment of the precut bit perfect you might be short on one edge or not perfectly square etc etc.
1 biggish piece just over the whole thing then trim with exacto knife.
gamart is the website i use to get my rolls of vinyl when i did the roof/bonnet wrap. im sure there'd be something like that closer to you guys and girls. ~30$ for a square meter for the avery supercast 900 stuff which is decent enough for flatish areas.
