my second problem of the night...
so when i plug my phone in to charge, via a cable into a double usb port into the cig-lighter, all radio stations develop a quiet static/hiss sound.
all stations, both FM and AM. and also when the cable is in either of the usb ports on my adapter.
problem is similar when i aux mode. however sound is more of a constant "bip, bip bip" sound, and much louder than the static of the radio.
hope this makes sense..
i have also used 3 different cables to no avail...
*Problem* radio and aux interference when charging phone
- Fizzlefuzzle
I Also have this problem! It's terrible when I'm trying to listen to my iPod and charge at he same time
<b> Proud owner of Australia's and club cj's first glitter pink 2011 CJ Mitsubishi Ralliart Lancer
</b>
Mod thread ; http://clubcj.net/viewtopic.php?p=297953
is there another cig lighter in your centre console?
if so have you tried switching to that one?
Syke
Check Out My Garage
Check Out My Garage
- Fizzlefuzzle
Yes I have 2 cigarette lighters and it does the same thing in both. I even bought another cigarette lighter to plug into it to see if there was any difference but there was none.
</b>
- evil.ralliart
hobba wrote:my second problem of the night... so when i plug my phone in to charge, via a cable into a double usb port into the cig-lighter, all radio stations develop a quiet static/hiss sound. all stations, both FM and AM. and also when the cable is in either of the usb ports on my adapter. problem is similar when i aux mode. however sound is more of a constant bip, bip bip sound, and much louder than the static of the radio. hope this makes sense.. i have also used 3 different cables to no avail...
The Bip Bip sound is the phone locating its signal...if you hold any phone next to a radio it will do this even if not on charge. You should have heard the racket the first digital phones made near a radio or any amplified device(Yes im that old...i remember swapping from analogue to digital)
As stated before...keep the phone as far away as possible from the head unit and its charge lead...also try a more expencive charge lead ...most of the cheap ones have little or no shielding. Try putting the phone in the arm rest console and using that charge point not the dash plug.
When the phone is plugged in the lead acts like an antenna/booster for the bip bip noise basically.
So...things to try:
1: Try a genuine apple lead or a better quality one.
2: Keep the phone as far away from the head unit as possible.Try putting it on the back seat with the lead totally wound out...At least you will know if this fixes the problem.
3: Dont coil the charge lead up as this may amplify the interference.
4: Run a fused lead directly from the battery to under your seat
5: If it is an iPhone Gently throw iPhone out of the driver side window preferably while vehicle is moving at hi-speed and replace with Droid.LOL
Note: I only use the centre console charge point with a 2 x USB 2 x Cig lighter adaptor inside the console and have never had any noise problems with the MMCS.
Hope this helps and best of luck with solving it.
Cheers
- itsagrantos
I have the exact same problem with my 09 VRX.
From the research I have done, the problem it is called 'Ground Loop Noise' meaning that the power and stereo are grounded to different quality grounding points creating potential difference between these two points, and when you connect your phone to the power and then to AUX, you complete the circuit and the small noise you hear is the interference of the small current flowing around the 'mini circuit'.
I personally believe this is not good enough considering I paid extra for the Rockford premium sound. If I had of known that I couldnt charge my device at the same time I would have purchased after market and had it installed properly unlike our factory stereos.
Has anyone been able to solve the problem?
I have read a number of US forum posts suggesting that re-grounding the AUX port solves it, but haven't given this a go.
n.b. dealers in AUS seem to have no idea about it.
[EDIT] I should also note that I have run a USB port directly off the battery and the noise continues , leading me to believe the problem exists on the AUX end.
- itsagrantos
In case anyone has this problem in the future, I have had mine fixed by MITSUBISHI.
The dealer has run a 'new' (not sure if there was one) earthing wire from the 12V power socket to the chassis.
This has eliminated pretty much 90% of the noise I was hearing when playing and charging at the same time!
I don't know if this was covered under warranty or not, but he didn't charge me.
