Need help with timing chain
scott_drake
Postby scott_drake » Mon Jul 08, 2013 5:53 pm
Hey all im in the process of replacing my timing chain to the new upgraded one.....My question is:
WTF am i ment to do with the oil squirter? do i leave it, do block it off??? Im hoping mcCoy can chime in here
SEB15
Postby SEB15 » Mon Jul 08, 2013 6:17 pm
Make sure you take some photos and post it up! This will be a handy DIY!
:D
scott_drake
Postby scott_drake » Fri Jul 12, 2013 10:45 am
cracked this aswell, leave the oil squirter in but cut a few mm off the nipple, no harm done, just straight swap the chain over, guides and tensioners only needed if they are worn out or damaged
empror
Postby empror » Fri Jul 12, 2013 2:06 pm
what parts did you purchase and what were the part numbers? i'm definitely looking into this, as my engine has copped some serious abuse over the last 5 years.
scott_drake
Postby scott_drake » Fri Jul 12, 2013 5:04 pm
Ill try digg up the part numbers, all u need is the timing chain and oil pump chain....guides and tensioners only needed if worn out/damaged...and lots of patience
empror
Postby empror » Sat Jul 13, 2013 12:43 am
Thanks man :) much appreciated. Did you just go straight to mitsu for them? Im just preparing my rectum for their pricing..
empror
Postby empror » Sat Jul 13, 2013 12:44 am
scott_drake
Postby scott_drake » Sat Jul 13, 2013 6:04 am
max $400 in parts if u get all the guides etc...timing chain 130, oil chain 110
labour 2-3days at home based with basic tools
Shop time 6-8hours max $110-$120 per hr
dealership quote for job 8hrs $978 plus oil ad filter
once installed u need to reset learnt value,
If u tuned u need to retune again otherwise u WILL knock and ping thats the only down side
scott_drake
Postby scott_drake » Sat Jul 13, 2013 6:05 am
