Best aftermarket Turbo for Evo X MR ??????
gman90
Postby gman90 » Mon Jul 29, 2013 7:56 pm
Hi All , Hey What are people running Best aftermarket Turbo for Evo X MR ?????? + could some of you please post dyno sheets to go with brand and cost of turbo Thanks Gary very Curious to see results :?:
jayce321
Postby jayce321 » Mon Jul 29, 2013 8:37 pm
Fp series red green black. Seems like alot of evo owners go them
el3ment
Postby el3ment » Mon Jul 29, 2013 9:33 pm
I'd look into getting the existing turbo high flowed... you'll gain quite a bit from it. Otherwise.. look into the MHI turbo
bunnishiwa
Postby bunnishiwa » Tue Jul 30, 2013 7:49 am
Depends on your power targets - you could go an EF4 if seriously high kw is all you are after. If you just want more of a kick, with minimal installation fuss and reasonable drivability then maybe a BBX, or if you want to keep spool as early as possible then maybe a BBX-Lite?
- Lowered on Kings
- Whiteline Rear Swaybar
Noli Timere Messorem
gman90
Postby gman90 » Tue Jul 30, 2013 9:35 am
Hi the fp green u can only get as upgrade u send yours and they upgrade and send back, the bbk lite has some good feed back on it, thz Gary
scott_drake
Postby scott_drake » Tue Jul 30, 2013 8:25 pm
Dont bother unless you are doing all supporting mods for it....
You want best gain value for money do this
Port, Polish and Ceramic Coat Manifold
Port, Polish and Ceramic Coat Turbo
Custom, high flow oil feed line, oil return line, water feed line, water return line
Turbosmart 18psi aquator
Retune
And hello 250kw at the wheels, cost, about $2.5K depending on who does the work,
scott_drake
Postby scott_drake » Wed Jul 31, 2013 6:30 am
Other wise
turbo
Turbo lines
Intercooler
Intercooler pipes
Full exhaust
Intake
Fuel injectors
Fuel rail
Fuel pressure regulator
Fuel lines
Fuel pump
Fuel surge tank
Aquator
Boost controller
Lots of tuning
Beeble
Postby Beeble » Tue Aug 06, 2013 11:34 am
GT pumps in sydney $1400, you send him your X turbo, he machines the housings, installs bigger wheels, and you have a +35kw turbo which spools about 200rpm slower than stock
probably the cheapest, reliable upgrade out there
5MT will get 300kw on E85, 250-260kw on 98 (assuming 220kw on stock turbo and 98)
http://BeebleTune.com
BST50N
Postby BST50N » Tue Aug 06, 2013 5:57 pm
Why not just the Garrett bolt on?
Beeble
Postby Beeble » Tue Aug 06, 2013 6:33 pm
in a word.... lag
the garrets are super reliable turbos. and for a bolt on solution for someone who will beat on the turbo they are very very good.
but if you look at say the Forced Performance turbos as a comparison :
the GTX3071 will get you same/slightly better top end power than a Green. but a Green hits 25psi at 3500-3600 in 3rd gear. a GTX3071 won't get there until 3800-3900 at best, about the same as a Red
A GTX3076 will get slightly better/same power as a Red
the Red will hit 25psi at 3800rpm in 3rd. The GTX3076 is after 4000, in fact about the same as Black.
so if you sit above 5000rpm the garrett GTX turbos will level peg the FP equivalent in terms of top end power and on/off throttle response.
But for that same top end power, the midrange simply can't compete as they take longer to get up to speed... so on the street they feel a bit doughy for the power they make up top, compared to some of the competition.
bunnishiwa
Postby bunnishiwa » Tue Aug 06, 2013 6:38 pm
Beeble wrote:GT pumps in sydney $1400, you send him your X turbo, he machines the housings, installs bigger wheels
Can you do this in Melbourne with a RA turbo? Similar to the CBRD upgrade in the states?
- Lowered on Kings
tencents
Postby tencents » Tue Aug 06, 2013 6:46 pm
^ interested in doing this to the RA turbo too
- GST basemap
- AMS boostpill
- Evo X BPV
- UR UICP
Beeble
Postby Beeble » Tue Aug 06, 2013 6:46 pm
^^ I don't know anyone local doing high flows for RA turbos like the RAD stuff from CBRD
but I am sure if there was some interest, someone like Mark would have a crack at it.
The down side is the RA snail is single scroll - so by increasing flow to say evo X rates , like the RAD turbo, it does get quite a bit laggier than the twin scroll evoX turbo.
Although I've tuned a few RADs now, they weren't too bad in terms of spool to be honest.
gman90
Postby gman90 » Tue Aug 06, 2013 8:28 pm
Hi ,yep gone with the OEM EVO X upgrade to the 712gtp specs!! Turbo arrives tomorrow up to toowoomba on friday fitted on Friday and tuned Saturday Fingers Cross hope it is all good Cheers Gazza :D
Beeble
Postby Beeble » Tue Aug 06, 2013 9:59 pm
26-27psi right across Gazza don't let them wimp out on you!
