Turbo Kit for 4B11 CJ Lancer
- Ozie
I Found this Turbo Kit for the CJ 4B11, here is the link http://www.roadracemotorsports.com/stor ... cts_id=286
- XxLaNcErGTSxX
XgunmetalcvtX
Not really hey. With that turbo kit, u can run at 0.4 - 0.6 bar boost without problems on the 4B11. However if u want more boost u will need to upgrade the internals. Its like any turbo. Even a tiny little turbo can blow an engine if the bar is set too high for what the engine can take at the moment.
________________________
Past: Nissan Xtrail 2.5
Current: Mitsubishi Lancer 2.0
Weight loss, tuning
Weight loss, tuning
XgunmetalcvtX
- Phoenix
i'll say budget out about AUD$10 - $12K at least. this will make room for your turbo + safety electronics + install + tune + brakes + RTA certification, AND... any mishaps...
but in the end, you'll have something that would eat a RA in a straight line... but of course, you'll die in corners...
PS: minus out $1 - $1.8K from my estimate if you're installing the kit and brakes yourself.
PS2: Frank is also selling custom forged internals, such as conrods, pistons, and crankshafts... that would allow you to up the boost to around 14 - 16psi... or higher...
Return to “2008+ Turbo Performance”
