Change these interior lights?
Cigarette lighter
If you want to run your cable out of the vent I can sell you just our charger module but not e cigarette. It mounts below the compartment in front of the shifter and is powered off the 12v socket harness. You could then connect a standard USB extension cord and route it where needed. The charger also has two outputs so you could power two devices if you wanted. PM me if you want more details.
Melvin Campbell
Just FYI...
http://clubcj.net/viewtopic.php?t=8523& ... c&start=15
Did this ages ago,
to do JUST the two facing down would take a matter of minutes... there is i believe 2 for memory that face down
Did this ages ago,
