SOLD SOLD SOLD
BST50N
SOLD SOLD SOLD
Postby BST50N » Tue Jan 21, 2014 9:13 am
SOLD SOLD SOLD SOLD
Ok so I've decided to sell this. Need funds for other things.
I have one Evo X turbo. Appears to be in excellent condition. The seller claimed it had under 8000 miles on it. I brought it in from the states.
I previously said it has no shaft play. I still believe that to be the case, but I'm not a turbo expert. After watching a number of youtube videos I've seen how they suggest a turbo is inspected. This one has zero back and forth movement. If you try quite hard to move the compressor turbine side to side there is a very small amount of movement. If you press perpendicular against the compressor turbine shaft toward the inlet hard with your finger you can reduce the clearance between the turbine blade and the housing, but it doesn't touch. It will still spin when you do this. I can't make the exhaust turbine move at all. Just wanted to be very clear and open about it. As I said, i don't think this constitutes shaft play, but I'm no expert on turbos. It appears to be in excellent condition. Compared to some of the videos on youtube its almost brand new!
Turbos are cheap in the states, but shipping them here is not :S
EDIT - Need this thing gone! I'm losing money now as I had to pay to have the stupid bolt removed as I couldn't in good conscience sell it to someone like that. $500 pick up price.
Comes with wastegate actuator and inlet elbow (not shown).
Postby sleeper » Tue Jan 21, 2014 9:22 am
thats a good price :)
squala
Postby squala » Tue Jan 21, 2014 9:31 am
Am I right that some Evos used TD05 and others TD06 turbos? Which one is that?
Thanks
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
el3ment
Postby el3ment » Tue Jan 21, 2014 11:40 am
Would be first I hear that evos come with a TD06... most I know are TD05
And good price for that turbo!!
BST50N
Postby BST50N » Tue Jan 21, 2014 1:02 pm
Yeah this one is a TD05
squala
Postby squala » Tue Jan 21, 2014 2:43 pm
PM'd
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
BST50N
Postby BST50N » Fri Jan 31, 2014 10:22 am
bump
R4LLI4RT
Postby R4LLI4RT » Fri Jan 31, 2014 10:29 am
:shock:
damn it if only i had the cash there are so many things i wana do to my car. i cant wait one more year of finance to go!
3Inch Custom Cat Back Exhaust
Home Brand Alloy UICP
K&N Panel Filter Replacement
DBA Extreme Pads
Turbosmart Dual Port BOV
Tein S Tech Springs
BST50N
Postby BST50N » Fri Jan 31, 2014 12:38 pm
R4LLI4RT wrote::shock: damn it if only i had the cash there are so many things i wana do to my car. i cant wait one more year of finance to go!
That's what credit cards are for 8)
R4LLI4RT
Postby R4LLI4RT » Fri Jan 31, 2014 1:37 pm
mine are maxed
DBA Extreme Pads
Tein S Tech Springs
BST50N
Postby BST50N » Fri Jan 31, 2014 2:06 pm
R4LLI4RT wrote:mine are maxed :(
haha yeah isn't everyones?
R4LLI4RT
Postby R4LLI4RT » Fri Jan 31, 2014 2:24 pm
well im actually gana do my exhaust next, i just got 2 cannons for it, only cost me $120 for 2, and i found a hotdog for $80 3inch, once i get that im gana see if i can find a cheap exhaust place and try get it fitted, if it can cost me less than $450 all up ill be really pleased.
DBA Extreme Pads
Tein S Tech Springs
BST50N
Postby BST50N » Fri Jan 31, 2014 2:26 pm
R4LLI4RT wrote:well im actually gana do my exhaust next, i just got 2 cannons for it, only cost me $120 for 2, and i found a hotdog for $80 3inch, once i get that im gana see if i can find a cheap exhaust place and try get it fitted, if it can cost me less than $450 all up ill be really pleased.
Nice - be sure to post photos and videos :D
Back to turbo sale - buy buy buy :P
BST50N
Postby BST50N » Tue Feb 04, 2014 8:40 am
I can't believe I missed this, probably as I was only concerned with the mechanical condition of the turbo and how it appeared to be working. I found there was a bolt/stud snapped off in one of the bolt holes :oops:. Has now been professionally removed.
Pick-up price $500 need it gone!
squala
Postby squala » Tue Feb 04, 2014 10:30 am
So has that bolt affected the turbo in any way?
Thanks
7 airbags
6-speed SST
5-star safety
4-wheel drive
3-diamond badge
2 overhead cams
1 awesome ride
