*CLOSED* Fumoto Valve CCJ GB - Insufficient Numbers
For all ClubCJ Members.
Postby ofey » Tue Jan 28, 2014 5:01 pm
Background
You can read more about the product here.
In short, install this valve and you can drain your engine oil without tools and without mess.
Just lift the lever of this solid brass ball valve and give it a quarter turn to open it.
Return the lever to its original position and it locks closed, double sealed to prevent leakage.
The Engine Oil Drain Valve is made of corrosion resistant forged brass and stainless steel.
The ball valve design provides a straight flow for efficient drainage and a perfect seal when closed. Frozen drain plug and stripped threads are eliminated forever.
OK, so the local supplier has it RRP = A$30 with postage of A$9.
I've arranged a group buy with the local supplier
And tiered pricing is as follows:
10+ valves – 10% off
20+ valves – 20% off
50+ valves – 25% off
100+ valves – 30% off (A$21 each)
I will be approaching a few other car clubs to help make up the numbers so we can get the 100+ orders but let's see how we go on our own club?
The part number for our Lancer (NA, RA or Evo is F-106).
If you want something else or the nippled version (F-106N, not advised for lowered cars) please state so else I'm assuming you're after the
Edit->OK so apparently I've been told the nippled version is the better option?
You have been warned.
Though it's slightly more expensive?
EOI List
VIC
1. ofey F-106N
2. squala F-106
3. squala F-109 E39BMW
4. Ledspy F-106
5.
NSW
1. feral F-106
2. feral F-106
3. LukeyBoi F-106
4. gondenk F-106
5. Hoges F-106
6. 27enemies F-106
QLD
1. zedd82 F-106
2. zedd82 F-106
3. Speedie F-106
4. Speedie F-106
8.
SA
1. himynameisdaniel F-106N
2.
Jason-VR
Postby Jason-VR » Tue Jan 28, 2014 5:06 pm
I would like members to be aware that fitting will also remove your magnet in your sump plug which traps any loose metal objects in your engine.
Postby ofey » Tue Jan 28, 2014 5:19 pm
My opinion? Think about the surface area your sump plug takes up?
Kimmy
Postby Kimmy » Tue Jan 28, 2014 6:59 pm
2x F-106
1x ADP-106
My ride thread: Click here!
My garage: Click here!
zedd82
Postby zedd82 » Tue Jan 28, 2014 7:54 pm
Jason-ES wrote:I would like members to be aware that fitting will also remove your magnet in your sump plug which traps any loose metal objects in your engine.
You can just get one of the magnets that goes around your oil filter and trap anything in there instead.
2x F-106 for me please ofey
Postby ofey » Wed Jan 29, 2014 11:22 am
wow seriously piss poor response?
feral
Postby feral » Wed Jan 29, 2014 11:30 am
The standard sump plug has no magnet anyway. Put me down for 2 x F-106. Thanks ofey
Speedie
Postby Speedie » Wed Jan 29, 2014 1:49 pm
2 x F-106 please Ofey
Postby ofey » Wed Jan 29, 2014 3:44 pm
zedd82
Postby zedd82 » Wed Jan 29, 2014 4:50 pm
ofey wrote:OK so apparently Ive been told the nippled version is the better option? You have been warned. Though its slightly more expensive?
Any idea on starting price for the nippled version?
zedd82
Postby zedd82 » Wed Jan 29, 2014 7:50 pm
TrojanHorse wrote:Apparently nippled isnt recommended for lowered cars so if ur lowered or thinking if lowering I wouldnt be going the nippled version. Ill just have the regular one still plz.
Thanks Erin, but I was actually asking for a friend who owns a different car that isn't lowered.
buchani
Postby buchani » Wed Jan 29, 2014 8:53 pm
1 x 106N thanks
Postby ofey » Wed Jan 29, 2014 8:57 pm
zedd82 wrote:Any idea on starting price for the nippled version?
A$34.
Users browsing this forum: No registered users and 88 guests
