[s]I'm after these[/s]:
[s]The whole switchgear assembly, not just the knobs! - from a 2012/13/14 model please!
Please PM me if you know of any...[/s]
Thanks!
Got them from Unis (thanks for the tip-off Brendan-Who-Knows-Things):
delta_fragma wrote:Climate control definitely does work, Ive done it. There arent any ETACS settings that need changing (Ive checked with a MUTIII). You need to install the temperature probe into the opening behind the vents at the end of the big trim piece, and connect it to a connector near the steering column. With regards to an MY13> one, youre in luck, I know where you can get one. Unis has one with the piano black trim that came out of an MY13 VRX, I was there a few days ago. Give him a call on 0404188505 tomorrow.
delta_fragma wrote:[quote:808896d601=Zaphod]Ta Brendan (you legend!) Ok if I just shoot him an SMS now? - any idea where I could chase the temperature probe? Cheers![/quote:808896d601] Ask him and make sure he throws it in with the A/C controls. [quote:808896d601=lantourismo]What is this about a temperature probe?[/quote:808896d601] Theres a thermistor inside a flexible conduit that plugs into the square opening just to the right of the hazard controls behind the trim panel.
