Questions about spray painting plastic engine bay cover?
babylancerx
Postby babylancerx » Fri Apr 04, 2014 10:04 am
Hey guys so I've been meaning to do this for a while but wasn't sure how and i didn't want to mess it up.
So I love spray painting and I really wanted to do some work on my engine bay but I never thought it was possible, because if you look at the covers they are a glossy black plastic cover and i thought the paint would just roll off it haha.
But I've seen a few people have it on here so I was just wondering if :
1) I needed to sand it down? If so what grit would I need and how many sheets? I only buy the wet or dry sand paper so if i do sand it will it be better wet or dry?
2) If I needed primer? If yes is the light grey VHT Engine Primer alright?
3) To clean the plastic covers will I need to use wax and grease remover or anything? Or is soapy water okay?
babylancerx
Postby babylancerx » Fri Apr 04, 2014 11:30 am
thank you so much x ill upload pics later tonight of the process haha
babylancerx
Postby babylancerx » Fri Apr 04, 2014 11:39 am
fine as in 2000 grit?
and yeah haha ill have to buy a fair bit of sand paper then :)
billyboy
Postby billyboy » Fri Apr 04, 2014 12:18 pm
I used steel wool to lightly scuff up the painting area, then cleaned with wax & grease remover.
Make sure you also spend the extra time to mask the area off with high quality 3M tape, its tedious but sloppy work will show.
Then applied a light coat of plastic primer, followed by 3 coats of colour & then 4 coats of clear topcoat.
Didn't use any fancy high heat paint, just made sure it all cured well & allowed nearly a week before putting the cover back.
My results:
http://img135.imagevenue.com/img.php?im ... _546lo.JPG
Give it a shot! :)
babylancerx
Postby babylancerx » Fri Apr 04, 2014 12:20 pm
wow thank you so much yours turned out awesome haha ill definately follow the steps thank you so much for the tips :)
billyboy
Postby billyboy » Fri Apr 04, 2014 12:36 pm
Cool, also forgot to mention get yourself some good quality paint as well.
I used PowerPlus pearlescent red from SCA, took a gamble & purchased their home brand clear topcoat & was impressed went on well, nice & shiny 8)
babylancerx
Postby babylancerx » Fri Apr 04, 2014 12:54 pm
haha yeah i can see i work at autobarn so i get engine enamel for a really good price and some topcoat too :)
babylancerx
Postby babylancerx » Fri Apr 04, 2014 1:50 pm
was it any good??
Return to “Queensland”
