workshops?
workshops?
Bit lazy to search properly here, but wondering if I could get recommendations for workshops to install parts and tune? Am about to embark on the X upgrade...
- rokpapaziz
turbo, manifold, lines, initial inlet pipe, injectors, gaskets that came with manifold, intercooler piping and intercooler, 3 port (if I can find it). May need additional bolts or gaskets. Hence why want to drop off at workshop, in case I've missed some things. Would like to see if possible to have workshop create inlet piping etc. Also looking at Tomei dump and front.
At the moment, talking with 999. But wondering if there are more experienced workshops that have done this work already.
Rik, i found this list be handy when sourcing parts, courtesy of evoM.
Required (a complete turbo assembly off an X should include all of this):
1515A183 (1515A198) Turbocharger 2,022.79
1555A476 Exhaust manifold 514.82
MN119784 Exhaust stud x2 (these will not come out of your Ralliart turbo without breaking) 9.73 x2
1515A184 Turbo to manifold gasket 44.10
1555A289 Turbo to 02 housing gasket 40.37
1555A423 O2 housing 171.77
1225a155 Oil feed line 27.22
1225A181 Oil return line 75.97
1310A469 Coolant return pipe 12.10
1310A577 Coolant feed pipe 25.20
MF650114 coolant banjo bolt x2 7.37 x2
MF660065 coolant banjo bolt gasket x4 0.95 x4
1542A042 Inlet elbow 61.08
1515A053 Inlet elbow gasket 10.10
1570B095 Downpipe 304.52 (it would be cheaper just to get a widemouth downpipe instead of stock Evo downpipe and O2 housing)
3078.50 + 27.22 +304.52 total list.
1055.71 + 27.22 + 304.52 without new OEM turbo
Recommended but not required to work:
1555A320 O2 housing bracket 19.08
MD194403 Oil return line gasket 1.53
1515A166 Compressor housing bracket 19.08
MF140264 Compressor housing bracket bolt 2.23
MF140260 Compressor housing bracket bolt 1.30
MR281085 Turbo outlet pipe gasket (same as Ralliart but new ones are recommended) 4.65
forget the pricing, its USD and out of date but the part numbers are correct.
- rokpapaziz
Users browsing this forum: Majestic-12 [Bot] and 3 guests
