Hi all,
Couple of quick questions. Have not owned my 10 mr for a week yet so still getting used to it and there is a couple of things I've noticed about the box.
First thing is when its in sport or and I'm using the paddles, when I take off I select second and it grabs third all by itself. Only gear that does it. Is that normal?
The second thing is, in sport or s sport, either the front diff or the box make a light clunk sort of noise when decelerating at low speed. It's not all the time and sounds kind of like locking the diffs on a 4x4
Like I said still getting used to it and want to make sure these things are normal!
Cheers,
Steve
10 mr gearbox
suzisteve266
- Lancer Learner
suzisteve266
- Lancer Learner
- Beeble
not normal on both counts.... definitely let dealer know about it and make sure it gets logged against the VIN *just incase* something bad happens down the track
http://BeebleTune.com
- rustybucket
Are you taking off in auto sport then changing to 2nd? Or manual sport?
If I am in auto sport change to 2nd it can jump to 3rd like you are explaining. Its as though I change gear at the same time the auto does or a split second apart.
I have also heard the light clunk when braking. If I was not driving it I don't think I would notice. Only seems to do it when it drops back to 1st say I'm slowing down for a round about and then begin to accelerate. I have a Ralliart though.
Here is my idea on what could be happening.
- Take off in auto mode in 1st
- Shift into 2nd using paddles at over 4000rpm
- Car has already changed into 2nd because it is in auto mode, so hitting the paddles changes it into 3rd
I had a similar "issue" when I forgot to put it into manual mode at the drags. Shifted with the paddles from 1st at 7000rpm but the car had already shifted into 2nd the split second that I hit the paddles. Ended up having to change back to 2nd myself...
230kw/430nm @ 24psi on E85
12.191 @ 108.81mph - Fastest stock turbo ralliart in Australia
www.facebook.com/BoostinJuiceTuningSydney
www.clubcj.net/viewtopic.php?p=369141#369141
- lancerdarryl
the sam wrote:Here is my idea on what could be happening. - Take off in auto mode in 1st - Shift into 2nd using paddles at over 4000rpm - Car has already changed into 2nd because it is in auto mode, so hitting the paddles changes it into 3rd I had a similar issue when I forgot to put it into manual mode at the drags. Shifted with the paddles from 1st at 7000rpm but the car had already shifted into 2nd the split second that I hit the paddles. Ended up having to change back to 2nd myself...
I can make mine do the same thing Sam
suzisteve266
- Lancer Learner
Good to hear!
