Hi guys did my Ralliart SSport last night, and have reassembled the files and written easy to follow instructions for anyone with a tactrix to flash the 2012 EVOX MR sst firmware to their Ralliart, giving them Supersport and Launch Control
here you can find the files and instruction for download in a zip on my google drive
https://drive.google.com/open?id=0BwiH3 ... EF2bVcta2M
Tactrix Supersport for Ralliart
- Shaun Patterson
Re: Tactrix Supersport for Ralliart
This may be a dumb question, but will this add the modes to the dash display so you can see if they're active?
- Shaun Patterson
what do u mean? do u drive a ralliart?
Yes, perhaps I didn't explain it well. When I flick up the mode control switch near the gear selector it changes the little word icon on the dash display to either 'SPORT' or 'NORMAL'. Does Super Sport mode show up there? How would you know the mode is active if it doesn't?
Yes it says s-sport. after you switch to sport you hold the switch down for 3 secs and it will then say s-sport on the dash. You need to be stationary though to go into super sport. You would not need this indication as there is no mistake when you are in super sport as the gears now shift with no slip, it's night and day really. There is no indication of launch control but neither does the Evo X but again there is no mistake when you have activated launch control but you only find out if the car revs to 5000 rpm while your foot is on the brake before launch.
enkei sc 22 wheels
enkei sc 22 wheels
- Shaun Patterson
you wont have supersport standard tho youy will have to install it on...
also you should alwasy drive is sport, or supersport if you do have it
Yep, got it. All my questions related to the upgrade. I am fully conversant with how the car works factory standard. Thanks for the answers
