Bulbs wont fit?
ciggo
Bulbs wont fit?
Postby ciggo » Fri Jul 22, 2016 6:31 pm
Hi all,
I recent purchased both the high and low beam replacement bulbs as I wanted a brighter light and longer throw. The lights I purchased are the Phillips Whitevision 4300k HB4 and HB3.
However when I removed the OEM bulbs and tried to replace them with the new ones I could not get them to fit. I wasn't even sure if the connector was attached properly to the bulb as it was a super tight fit and didn't click in nicely. No matter how hard I tried I couldn't turn the bulb into the headlight. It was as if the screw in part of the bulb was too big.
Am I doing something wrong? Any help is appreciated :)
Re: Bulbs wont fit?
Postby Lancer1993 » Fri Jul 22, 2016 8:30 pm
Not sure if I can help but yes they are a pain to fit, make sure you're using the right ones in the right holes.
andrew.costa
Re: Bulbs wont fit?
Postby andrew.costa » Mon Jul 25, 2016 7:29 pm
Took me a while to get them to click in, but the HB4 and HB3 are correct.
Re: Bulbs wont fit?
Postby Lancer1993 » Mon Jul 25, 2016 9:26 pm
Did you move the washer filler on the drivers side?
I found it harder to get mine out than the new ones in, went for HB3 4300k and HB4 4100k, not a huge change but they are good.
Users browsing this forum: Google [Bot] and 2 guests
