How to kill a 4B11 engine
Postby lancerdarryl » Thu Feb 14, 2019 3:52 pm
Background.....4B11 engine 90,000 klm in a 2011 ASX Mitsubishi.The car hasn't been serviced for 40,000 klm.
Because of the lack of oil changes the sump had a large amount of sludge build up and blocked the oil pump pick up. This resulted in a loss of oil pressure.The top of the engine was fine but the crankshaft bearings suffered a catastrophic failure in particular #4 big end and piston and the main bearings at the end of the crank. The engine is beyond repair.
Re: How to kill a 4B11 engine
Postby Lancer1993 » Thu Feb 14, 2019 9:00 pm
I'm assuming not having it serviced for 40k km voided the warranty?
Viking
Postby Viking » Thu Feb 14, 2019 9:19 pm
I would hope so. People like that need to be taught a lesson in how to look after their belongings...
Quismiff
Postby Quismiff » Fri Feb 15, 2019 8:18 am
At most I miss a service by 5k and even then I'm stressing about it... but to skip one by 25k, the person who ignored the service due warning, or turned it off at all, needs a clip around the ear...
2007 MY08 VR-X (cj-red)
fearfulmaster2
Postby fearfulmaster2 » Fri Feb 15, 2019 8:50 am
And yet, they are allowed to have as many children as they want.
kris42
Postby kris42 » Sat Feb 16, 2019 5:49 pm
I bet he goes around telling people they are shit engines too.
Postby lancerdarryl » Sat Feb 16, 2019 9:17 pm
The car does about 5k per month and the young woman who owns it was told by a friend it only needs servicing every 6 months or so.Not particularly good advice.
fearfulmaster2
Postby fearfulmaster2 » Sun Feb 17, 2019 4:13 pm
Girls often treat a car like a television. Switch it on and off. Too bad she doesn't have a real man in her life to prevent her from bumbling into motoring disaster. How much is a recon engine, 3k fitted?
Postby lancerdarryl » Sun Feb 17, 2019 4:21 pm
$4500 including all fluids,filters and a general service.We fitted a low k second hand engine.
burfadel
Postby burfadel » Sun Feb 17, 2019 5:50 pm
The 4B11 engine looks to be used in the 2020 ASX, which is such a major update is basically a new car apart from the driveteain. Maybe it uses a 4J11?
cooyarpjm
Postby cooyarpjm » Sun Feb 17, 2019 6:39 pm
burfadel wrote:The 4B11 engine looks to be used in the 2020 ASX, which is such a major update is basically a new car apart from the driveteain. Maybe it uses a 4J11?
If you go by the "2018 Grand lancer ad" for Japan it will have the 4j10 engine 15.7km/L, LED head lights and tail lights, CVT8, only 6 airbags "RISE" (Realised Impact Safety Evolution) FULL LCD Instrument cluster (On non base models), the usual ABS, EBD, TCL, ASC. And it also looks like Mitsi have gone back to a separate display for climate control.
I know that when vehicles come here that some of these features may be absent or different and this is only indicative. and also I cannot read Japanese so don't know what half of the things written on the screen are lol.
about 5:30 into the video they go all out showing the different configs for the LCD cluster
Link to video https://www.youtube.com/watch?v=-l_Y3qnSYCU&t=337s
So maybe the ASX will also use the 4J10
No longer own a lancer, Fairwell. *yield*
burfadel
Postby burfadel » Sun Feb 17, 2019 9:12 pm
Apparently it's 2.0 L which would make it the 4J11. Even these are fairly old now.
Postby Lancer1993 » Mon Feb 18, 2019 6:23 pm
lancerdarryl wrote:The car does about 5k per month and the young woman who owns it was told by a friend it only needs servicing every 6 months or so.Not particularly good advice.
So 5k a month you'd want a service at least every 3 months.
New (used) engine, expensive mistake!
Gleno
Postby Gleno » Sun Mar 31, 2019 9:11 am
I have my oil changed on my lancer every 10K, I now have 340,000 on it and still runs like new, although slightly less power compared when I bought brand new back in 2010. Still original water pump, fuel pump, alternator, radiator.
Users browsing this forum: Google [Bot] and 18 guests
