FS: OEM Ralliart Coilovers
Ral1rt
Postby Ral1rt » Mon Jan 04, 2010 8:44 pm
ITEM: OEM Coil overs from my 2008 Ralliart
ITEM CONDITION: Basically brand new. I bought the car from Frankston Mitsubish, drove it 300m down the road to pedders for my adjustable coil overs.
REASON FOR SELLING: There taking up space in my garage!
PRICE AND PAYMENT CONDITIONS: Make me an offer! Pick up only, Far too heavy to post. I can also drop them off if convenient.
CONTACT INFO: PM Me
PICTURES: Will post if requested.
@SIR-VRX if you have any info on these coilovers can you post them up please as I dont know anyhing about them :-)
Owner: Matt Stewart
09 Ralliart tuned at MPC
13.22 @ 106mph Australia's 2nd fastest Ralliart. (Ill get you captain :-) )
SIR-VRX
Postby SIR-VRX » Mon Jan 04, 2010 9:47 pm
They aren't coilovers per-se. The rears are Coil-over-strut design but not called coilovers like the ones everybody knows. The fronts are McPherson Struts.
The springs are a different spring to regular Lancers, resulting in a higher ride height for the regular models. From memory the spring rate is stiffer, and the taper is different.
That's about it. :)
Ral1rt
Postby Ral1rt » Mon Jan 04, 2010 9:54 pm
Thanks mate! Muchly appreciated!
Owner: Matt Stewart
SIR-VRX
Postby SIR-VRX » Mon Jan 04, 2010 9:54 pm
No worries. Good luck with the sale...
Ral1rt
Postby Ral1rt » Mon Jan 04, 2010 9:56 pm
Cheers man, but after reading that info i'll probably have to give them away! :-) haha
The strut's should be good with lowered springs though yeah? Better than oem Lancer?
Owner: Matt Stewart
SIR-VRX
Postby SIR-VRX » Mon Jan 04, 2010 10:26 pm
I'm pretty sure the struts are the same actually. Can't confirm though.
exaltd
Postby exaltd » Mon Jan 04, 2010 11:01 pm
Hmmm.... sounds interesting.....
So they aren't coilovers, but they give our Lancers Ralliart suspension? Is that right?
And a higher but stiffer ride than the normal ES springs and shocks huh? Will they fit the ES? :)
If price is lower than springs, i might consider :P
SIR-VRX
Postby SIR-VRX » Mon Jan 04, 2010 11:05 pm
It is stock Ralliart suspension.
It is higher and firmer, yes.
I can not confirm if they fit the regular Lancer range. I heard that the base of the rear struts might be different, but I can't confirm.
Ral1rt
Postby Ral1rt » Mon Jan 04, 2010 11:06 pm
I think they will fit the es, i'll have to check with SIR-VRX *bump*
Put in an offer mate... all considered. as I said, there only taking up space in my garage and i'd rather sell them cheap to one of you boys than on ebay
Owner: Matt Stewart
exaltd
Postby exaltd » Mon Jan 04, 2010 11:06 pm
Hmmm... if can not confirm by Adrain,
I better play it safe :P He's never been wrong :P
SIR-VRX
Postby SIR-VRX » Mon Jan 04, 2010 11:10 pm
To me, the look like they will fit. I would say it more than likely would. I have had a close look to compare, but never tried to fir them up.
But I can't confirm a definite yes or no. Worth a shot IMO.
exaltd
Postby exaltd » Mon Jan 04, 2010 11:20 pm
Hmmm..... decisions decisions.....
Because I'm not installing it (I have no clue how to install springs and shocks)...... it wouldn't be worth me buying these, then having them not fit, and having to pay labour for the time used.
I think I'm going to have to back out here mate. SOrry about that.
Good luck with your sale though :)
Ral1rt
Postby Ral1rt » Mon Jan 04, 2010 11:27 pm
No probs mate, ill do some investigationing to find out if they fit or not :-)
Owner: Matt Stewart
SIR-VRX
Postby SIR-VRX » Mon Jan 04, 2010 11:29 pm
Dan McCoy from TMR would probably know
Ral1rt
Postby Ral1rt » Tue Jan 05, 2010 9:47 am
I've just sent a PM to Dan M'ccoy so I should have some information soon
Owner: Matt Stewart
