Hey guys
friend of mine has an old merc, and her boyfriend 'drove it too hard' and now the brake discs/pads need replacing.
Im thinking 'that cant be too cheap on a merc' and then i suggest generics and she rkns it HAS to be merc only parts because "generics dont fit". Apparently she had generics put in last time and they didnt fit properly and squeaked a bit, til she had Merc ones put in.
Now I'm no expert and dont claim to be, but surely there would be generic ones that would fit? As a cheaper alternative?
Brakes question - friends car.
- Josh_Emerton
I'm sure Merc would have told her that they have to be genuine parts, but if a reputable brake manufacturer makes a part that they say fits the model, I'm certain they would work fine. Brake discs can't tell what logo was on the box the pads came out of.
- tadz0rz
I think the squeeking in the brakes more comes down to the compound in the brake pads. When i did mums fiestas brakes, they didnt have the OEM spec brake pads. Ie the ones i got were cheaper than the OEM and worse.
If the compound in the brake pad has too much metal in it it can cause the sqeeking or squeeling noise...
But i could be wrong...
- Josh_Emerton
- Josh_Emerton
I'd be putting my money on the fact that if he's driven the car hard (and I presume that included hard breaking) then he's glazed the rotors... in which case most, if not all compounds would squeek.
But yeah Tads if on the right track... It could also be as simple as some breaks have a small metal plate that sits on the break pads... when the pads are worn too low they will vibtare against the rotor indicating that its time for new pads
Hope that helps mate
