Sportback Real Lights
Usif
Postby Usif » Wed Sep 22, 2010 3:33 pm
Hey guys, quick question; how does one exactly get to the lights for Sportback? If case one burns? Or I want to modifty it sometime down the track? Cause It's all covered off. . . If anyone has any pictures, that would be great!
bunnishiwa
Postby bunnishiwa » Wed Sep 22, 2010 3:43 pm
Err... WHich lights?
- Lowered on Kings
- Whiteline Rear Swaybar
Noli Timere Messorem
milobob
Postby milobob » Wed Sep 22, 2010 4:09 pm
Is it in the manual? I know changing the front lights is in the manual and so are the rear licence plate lights...
vi93r
Postby vi93r » Wed Sep 22, 2010 6:13 pm
There are 4 access panels all up. (2 either side) (2 on hatch & 1 each corner behind wheel well).
To access reverse/brake lights (attached to tailgate), there is a panel on either side remove it with a screw driver and you can access globes.
To access indicators/rear park lights (corner of car), lay across the boot and look up in the alcove between wheel well and rear end, there is a little cover you need to pop out to gain access to globes.
Reverse globes are T15, never checked other globe sizes
Usif
Postby Usif » Wed Sep 22, 2010 8:18 pm
Yes Its Manual, 2009 Model VR Sportback - & Thanks vi93r. . . Too bad I ordered T20s - Presuming they were the same as any other 2009 model lancer... awh well only lost 11c *shrug*
