Apa Khabar ?
alxand_mitsubishi
Apa Khabar ?
Postby alxand_mitsubishi » Sun Oct 31, 2010 11:53 pm
means : how r u?
alxand here, reporting from malaysia
please feel free to check us out at www.lancergtclub.com :)
anyway, main idea to join u guys to check if u guys know wat wnet wrong n how to fix
problem sources : etacs ecu
sign : hazard light n turn signal dun work, check with MUT3 n show problem with etacs ecu, but i dun have it's diagram / wiring diagram to check which relay to change, since car's over warranty so thought of DIY :)
cheers
alxand_mitsubishi
Postby alxand_mitsubishi » Mon Nov 01, 2010 6:15 am
p/s
i'm driving the Lancer CY4A 2.0 CVT since 2007,
so it's been a 3 years plus of a good ride, till recently when the etacs gimme small problem :)
cheers to all here :)
Postby sleeper » Mon Nov 01, 2010 7:03 am
hi mate, welcome to clubcj :)
got a lot of members in your club:)
btw, i tried to register but "how many days in a year" field wont work, last i checked it was 365?
also i couldnt find a ralliart in your lancer model field?
cya round.
JaCe
Postby JaCe » Mon Nov 01, 2010 8:21 am
welcome aboard.
ps. baik baik :)
RyanMK
Postby RyanMK » Mon Nov 01, 2010 11:31 am
sleeper wrote:hi mate, welcome to clubcj :)
cya round.
Same happened to me when I tried about 2 nights ago. :cry:
Postby ofey » Mon Nov 01, 2010 11:53 am
I don't understand your problem. If the ETACS ECU is at fault, why is it you think that changing a relay will help? Where are there relays in an ECU? An ECU is a black box device like a computer's motherboard. Mitsu will never allow anyone to know the internals of an ECU. And if a transistor or something is at fault in there, I think that's the end of your ECU.
The MUT 3s/w probably tells you that the ETACS ECU has detected a fault. Big difference between detecting a fault and IS THE FAULT.
Now if a fuse has blown you can replace it.
Have you considered checking the fuse which ties in to your signal lamps?
alxand_mitsubishi
Postby alxand_mitsubishi » Tue Nov 02, 2010 2:14 am
hi there... days in a year, either 365 / 366, 365 make sense :)
no Ra coz it wasn't sold here :)
MUT3 shows a fault, "turn signal short curcuit" something like that...
n service center told it's the etacs internal, then a check with mitsu ppl, they says there's relay in the ecu etacs which could be the culprit,
fuse is all ok,
when we erase detail on mut3, it works for few second b4 the signal n hazard died again, means fuse n singal all in working condition but etacs detect abnormal activity hence they cut power to signal,
i think there's 2 posiility, wiring to signal / hazrad at fauklt hence short curcuit detected or the relay tat controls the signgal is as fault :)
Postby ofey » Tue Nov 02, 2010 6:58 am
Try this.
Take out all of your signal bulbs or connectors. There are 6 in the car. 2 front, 2 side and 2 back.
Slowly test 1 by 1. Then 2 by 2 and so on.
See if any one set is at fault. You could at least narrow down a wiring loom problem.
You do realise you can download a copy of the Mitsubishi Service manual online and then find your relay there.
MJL1217
Postby MJL1217 » Tue Nov 09, 2010 3:41 pm
baik baik saja!
MANI
Users browsing this forum: No registered users and 75 guests
