Engine start
age69er43
Engine start
Postby age69er43 » Thu Mar 03, 2011 8:22 am
Has anyone had any trouble with there's not starting? Example, it will crank for two sec then die? This has happened so many times...
Postby ofey » Thu Mar 03, 2011 8:32 am
Battery perhaps?
age69er43
Postby age69er43 » Thu Mar 03, 2011 8:47 am
Nah its not the battery, I tested it
silvervrx
Postby silvervrx » Thu Mar 03, 2011 10:12 am
starter motor maybe
Frazza
Postby Frazza » Thu Mar 03, 2011 11:07 am
age69er43 wrote:Nah its not the battery, I tested it
When you tested it how many volts did it have, if it dropped a cell it might show charge but not enough to crank
MY10 Golf R | 5 Door | Rising Blue Metallic | DSG | MDI | Black 19" Talladega | Motorsport Seats | Bluetooth | Sunroof | RNS510 + DYNAUDIO 300W
driftnut((
Postby driftnut(( » Thu Mar 03, 2011 3:19 pm
yer mate mine has done it a few times as well
exaltd
Postby exaltd » Mon Mar 07, 2011 12:45 am
Yes. Could be either faulty battery, weak battery or dead starter motor. Try all those first.
Testing it, should have no less than 9V on start up.... minimal high 8's with weak and long crank. Optimal around 10-11V.
Then test each individual cell for a charge - 2V+ in each should be (6 cells).
Then check the starter motor for charge.
Failing all this, check for leads and anything that could be out of the ordinary. If everything fails, call your mechanic :P
Hope that helps.
Users browsing this forum: ninjacatfish and 10 guests
