**Official Stance Thread**
PYLee
Postby PYLee » Sat Oct 22, 2011 9:23 am
Morning ladies and gents,
I'm making this thread so that all you guys out there with aftermarket wheel and/or aftermarket suspension could post up the details of it (ie size width offset of wheels and what suspension with height settings and alignment settings). This way , it will help provide a great reference to anyone that is out there with questions, trying to figure out how their car will look with a particular size.
Feel free to post up other people (quoting them with their username and which forum)'s setup with the available information.
I'll start by posting my current setup.
Wheels : Volk Racing TE37 Super Lap
Size : 18x9.5 +22 offset
Tyres : Hankook Ventus V12 265/35/18
Suspension : Stock
Alignment : Stock
Comments : 18x9.5 +22 is a great size for an overall look , nothing over the top yet flush. If i were to get another set , it will definitely be a set of 18x10.5 +22 or +18 for more hellaflush setup :)
Cheers guys :wink:
Lancer Evolution 10MR
billy boy
Postby billy boy » Sat Oct 22, 2011 10:27 am
Wheels : Volk Racing CE28n
Size : 18x9.5 +28 offset
Tyres : Sivlerstone Evo8 245/40/18
Suspension : Racing logic coliovers -
Alignment : - 2 camber
Comments : i love the look of these rims, maybe a touch too aggressive, but i made my car fit the rims - rears are flared 12-15mm - if i had my time again, may have looked at 18x9 +36 super flush without the need for flaring / repainting. would i really change it though? not on your life *cool* thinking of going 265 35 with the next tyres, so will need to work the fronts
235 and pre-defect (now it's 15mm higher)
245 and normal ride height (although it's a touch compressed / lower than normal due to the slight turn)
juanito
Postby juanito » Sun Apr 01, 2012 7:14 am
Good thread. Buying new set up soon. Pics would be great too.
@ PYLee & Billy Boy: U guys have +22 and +28 offset with 18x9.5. Do u guys hit the guards?
@ PYLee: Can u post up some pics pls? cheers
Postby sleeper » Sun Apr 01, 2012 7:33 am
thats aggressive for a RA bill :)
Postby SAM-24A » Sun Apr 01, 2012 9:32 am
Wheels
Type: Apec F11's / Zumbo Siphon
Size: 18" x 8" x 40mmET (offset)
Tyres: Bridgestone Potenza RE003 ... 225 x 45 x 18"
Suspension
Shocks: Factory KYB Firm Range Shocks (RA/VRX)
Springs: Eibach
Sway Bars: Whiteline ... Front 24mm / Rear 24mm + Lateral Locks.
Strut Brace: Whiteline ... KSB638.
Rear Brace: Alutec ... Upper & Lower Brace Bars.
Suspension Set-Up
Lowered: 30mm
Front: 1* Neg Camber / 1mm Toe-In
Rear: 1* Neg Camber / 3mm Toe-In
Wrap-Up
Nothing Overly Done ---
Tightened & Tweaked just enough to behave adequately for Spirited Road use whilst conserving Tyre wear .... :)
Merlinised AspiRe 2.4L
Postby JustinR » Sun Apr 01, 2012 10:33 am
Wheels : Privat Kontakt
Size : 18x8.5 +35mm ET
Tyres : Toyo Proxes4 235/40/18
Suspension : Stock
Alignment : Stock
Comments: Car looks more aggressive with the fatter tyres from the back & because they sit outside the guards. Car will need to be lower to give it a better stance though. Also, will need to roll the guards, have noticed with passengers in the back, or going over potholes too fast, back will rub/hit.
LaNcE
Postby LaNcE » Sun Apr 01, 2012 2:14 pm
Wheels : Enkie RPF1
Size : 18x9.5 +15 offset
Tyres : Toyo Proxies 4 245/40/18
Suspension : tein springs soon to be BC's
Alignment : f: -2 R -1.5
Comments : could do with a bit more low and bit more guard roll so i can fit fatter tires.
lee: should post up pics too! =P
funnyfi
Postby funnyfi » Sun Apr 01, 2012 6:02 pm
pics from side of each setup would be great!
Tweak
Postby Tweak » Sun Apr 01, 2012 6:30 pm
Wheels : Orign DNA
Size : 18x9 +30mm ET
Tyres : Falcon 245/40 r18
Suspension : Racing logic coil overs
Alignment : Not sure cant remember. Until i can get Rear guards rollers and flared then it will sit better.
billy boy
Postby billy boy » Fri Apr 06, 2012 12:58 pm
juanito wrote:Good thread. Buying new set up soon. Pics would be great too. @ PYLee & Billy Boy: U guys have +22 and +28 offset with 18x9.5. Do u guys hit the guards? @ PYLee: Can u post up some pics pls? cheers
sorry, missed the q - there was a bit of work getting it to fit - the rears were pulled to fit the 235 / 245. fronts didn't require any work up to 245. i've ordered 255 35 and will need to roll the front to fit a bit better (265 was a bridge too far)
tadz0rz
Postby tadz0rz » Fri Apr 06, 2012 6:20 pm
Wheels: Evo X BBS RS GT
Size: 18x8.5 38mm Offset
Tires: Carbon Series CS88 235/40/18
Suspension: Pedders lowering springs
Alignment: Uhhh....
Comments: Fitted to my ES Lancer. Perfect fitment on the front and rear gaurds. Need to roll rear guards to stop rubbing. Need maybe a 5mm spacer for the rear and some negative camber to get the stance im looking for but sits nice and flush for the moment :)
rayray
Postby rayray » Sat Apr 14, 2012 3:01 pm
Wheels : Work CR Kai Bronze
Tyres : Stock Yokohama Advan A10 215/45/18
Suspension : BC BR Coilovers
Alignment : Approx. -1.5 camber all round
Comments : 18 x 8.5 +30 makes it perfectly flush! nice aggressive fitment on the NA/RA Lancers.
RyanMK
Postby RyanMK » Tue Apr 17, 2012 11:18 pm
rthieu wrote:Wheels : Work CR Kai Bronze Size : 18x8.5 +30 Tyres : Stock Yokohama Advan A10 215/45/18 Suspension : BC BR Coilovers Alignment : Approx. -1.5 camber all round Comments : 18 x 8.5 +30 makes it perfectly flush! nice aggressive fitment on the NA/RA Lancers.
Pictures!!!! :D
big_d
Postby big_d » Thu Apr 19, 2012 8:07 am
Yes, pics on everyone's post would be great.
SAM-24A wrote:18 x 8 x 40mmET (offset)
Falken FK452 ... 225 x 45 x 18
That's the same set-up i'm going for.
Did you need to roll the guards at all Sam? How do you find the Falken FK452's?
Return to “Image Gallery”
